Home > General > have rrs's only got 5 gear's?
Page 3 of 4 <1234>
MAW
I tried it - 6th is not used in sport mode at any point up to 90 on my private test track....
Post #225653 Fri May 15 2009 10:27pm
PJPR01
United States 2013 Range Rover Sport 4.4 V8 HSE Orkney Grey
Another SW wrote:
will_wonka wrote:
Has to be a fake picture, Bobby is never wrong Whistle Whistle Cool
Don't take my word for it guys... go try it for yourselves... Rolling Eyes
Just out of interest, the official workshop manual also says "5th gear isn't used"... (along with one or two other things that aren't quite technically correct either... Wink )
Another SW is 100% correct. I've tried this today, and with the car on cruise control, shifting from full automatic to sport mode, the transmission does stay in 6th gear as evidenced by the tachometer, and you can prove it by shifting upwards so that 6 appears and you'll notice that the RPM's do not increase. The only thing is you don't have to be above 82 or 85 mph as previously stated, it works just fine at 60, 65, 70, 75 as well...yes, I tested at all 4 speeds. It could very well work below that as well, but with traffic flowing much faster, didn't have the chance to test it. By the way, mine is a 2006.
So...there does appear to be something about invoking the cruise control that doesn't trigger the downshift into 5th gear. PJPR
2017 FFRR TD6
Former LR: 2013 RRS, 2006 RRS
Post #225673 Sat May 16 2009 3:04am
Bobby
Great work and great news! If you're right this means there's an angle that LR overlooked! Congratulations!!
Meanwhile, some clarifications please..
1. You were in cruise control driving in 6th gear when you shifted to 'Sport'. Did the vehicle continue travelling in 6th for some distance? How did you confirm it did not downshift to 5th? If it did stay in 6th, why did you have to 'prove it'? Surprised
2. Do you realise that when to "'prove it' you shifted upwards so that 6 appears", you inadvertently went into CommandShift mode? The minute you push the stick up or down, you're out of Sport and into CommandShift. And of course it will go into 6th (and low RPM) in CommandShift mode!
You should try this again to clear the ambiguities.This time without going into CommandShift.
I hope you succeed and prove that LR can be sometimes wrong! Laughing Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #225725 Sun May 17 2009 3:32am
PJPR01
2. Do you realise that when to "'prove it' you shifted upwards so that 6 appears", you inadvertently went into CommandShift mode? Yes...fully aware of this, that's the reason for the test above. The minute you push the stick up or down, you're out of Sport and into CommandShift. And of course it will go into 6th (and low RPM) in CommandShift mode!
Hello Bobby...my response below may be a bit redundant from what I've written above, as the answers are contained, however, I'll add a few intermediate steps to detail what I meant by proof...hope this clarifies. By the way, all credit to ASW...he discovered this, I just tested his finding.
So...in order of logical sequence of activities:
1. Driving on the highway in full automatic mode at any of the speeds mentioned above, let's say 70 mph as an example, although I did the test at several speeds. Notice that car is already in 6th gear based on the RPM's. How to confirm this?
1a. Shift to Sport mode, then shift to 6th gear, notice that the RPM's are the same as when in full automatic...that confirms the 6th gear rpm level.
2. Now shift back to full automatic mode at 70 mph.
3. Set cruise control - verify that rpm's don't change (they stay the same).
4. Shift to Sport mode - notice that RPM's do NOT change...stays the same...continue driving for several miles as test...rpm's stay the same, car does not downshift into 5th as long as maintaining car on a flat level, obviously a hill or incline will force the downshift to maintain cruise control desired speed.
5. Redundancy check: "double check" RPM's again by shifting upwards from sport mode to make 6 appear...notice that rpm's don't change.
So...it appears that the throttle setting invoked when activating cruise control somehow overrides the automatic kickdown when shifting from automatic to sport mode...
Now that we know there are some bypasses, maybe we can figure out how to bypass that annoying "Low power mode" volume cutoff when the key is out of the ignition and one wants to play the radio louder than volume 20. PJPR
2017 FFRR TD6
Post #225726 Sun May 17 2009 4:06am
Bobby
Great work! Thumbs Up Malaysia Boleh!
Post #225727 Sun May 17 2009 4:10am
Another SW
Just to add to PJPR01's test above, if you are already in Sport Automatic mode and above 80 mph (may work at lower speeds, I haven't tested it) and then switch on cruise control, it will engage 6th gear when you go downhill or on the flat and the throttle is relaxed.
I believe that it will also engage 6th without cruise control above 82 mph with light throttle, but I keep forgetting to test this (on my private test track of course).
While we're on the subject of private test tracks Whistle does anyone else do the 3 seconds over 100 mph to drop the suspension for a quicker 'lap-time'? Thumbs Up As long as you don't drop below 80 mph for more than 30 seconds it stays low(er) Mr. Green
Post #225756 Sun May 17 2009 2:51pm
C10KO
Just read this topic through and have a question bit out of the topic.
MAW where is your private test track if I may ask??? Rolling Eyes
I would love to finaly try what is the capability of the V8 Whistle
Post #225757 Sun May 17 2009 3:10pm
PJPR01
I was not able to make the first item work even with very light throttle...it just stayed in 5th all the time, maybe with a tail wind and downhill it might trick it, but I couldn't do it.
On the +100 mph, a recent test here on a safe wide open stretch of highway in the desert, honestly I couldn't tell, but at those speeds, both hands are on the wheel, eyes glued to the road, I'm not sure one can even feel the minute drop, but it also doesn't seem to indicate anything on the dash (like highway mode or something to that effect would be cool). All I can say is that it loves to run at these speeds and could do so all day long. Very Happy PJPR
2017 FFRR TD6
Post #225764 Sun May 17 2009 4:50pm
Another SW
I'm afraid the Big Brother Speed Nannies stopped there from being a dash indication of the lowered suspension at high speed, but it does drop 20 mm and you notice the stiffer suspension on cornering (and on bumps - not in a good way!) It also feels a little more stable - especially in cross-winds.
Of course it is not something that I would ever do on public roads Whistle , but handy at the Nurburgring... Thumbs Up
Post #225766 Sun May 17 2009 4:59pm
C10KO
Do not know what does this have to do with the 6th gear but I am certain that the car lowers at high speeds. On the FFRR you even used to get an indication when it did... Unfortunately the RRS and after 06 FFRR do not indicate it anymore but still do drop 20mm Whistle
Post #225767 Sun May 17 2009 5:09pm
Another SW
That's because from 2007 MY FFRR got the D3/RRS suspension and dropped at 100 mph instead of the previous 60 mph. So no longer legal speeds in most parts of the World and we couldn't have people trying to get the indicator to show in the dash at 100 mph now, could we? Whistle
Post #225774 Sun May 17 2009 7:31pm
C10KO
Hmmm, will try it next time I am over in SK and take a pic what message do I get on dash Very Happy
Post #225779 Sun May 17 2009 8:26pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Just back from a jaunt to those unrestricted autobahns Smile
Gave the car a bit of wellie in sport mode (NOT command shift) and she was in 5th up to about 170km/h and was changing up into 6th as the speedo was getting to 180km/h, topped out with the speedo reading just over 210km/h so I guess it uses all 6 gears in sport mode Thumbs Up
Car is a October 2007 (MY08) TDV8 Sons of dogs come hither and get flesh
Clan Cameron
Post #226162 Wed May 20 2009 4:11pm
PJPR01
Pics? PJPR
2017 FFRR TD6
Post #226181 Thu May 21 2009 12:05am
Alicatt
It will be a few days before I'm back in Germany, Whistle Sons of dogs come hither and get flesh
Clan Cameron
Post #226207 Thu May 21 2009 9:32am
Page 3 of 4 <1234>
