![]() | Home > General > have rrs's only got 5 gear's? |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I tried it - 6th is not used in sport mode at any point up to 90 on my private test track.... |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
Another SW is 100% correct. I've tried this today, and with the car on cruise control, shifting from full automatic to sport mode, the transmission does stay in 6th gear as evidenced by the tachometer, and you can prove it by shifting upwards so that 6 appears and you'll notice that the RPM's do not increase. The only thing is you don't have to be above 82 or 85 mph as previously stated, it works just fine at 60, 65, 70, 75 as well...yes, I tested at all 4 speeds. It could very well work below that as well, but with traffic flowing much faster, didn't have the chance to test it. By the way, mine is a 2006. So...there does appear to be something about invoking the cruise control that doesn't trigger the downshift into 5th gear. PJPR 2017 FFRR TD6 Former LR: 2013 RRS, 2006 RRS |
Hello Bobby...my response below may be a bit redundant from what I've written above, as the answers are contained, however, I'll add a few intermediate steps to detail what I meant by proof...hope this clarifies. By the way, all credit to ASW...he discovered this, I just tested his finding. So...in order of logical sequence of activities: 1. Driving on the highway in full automatic mode at any of the speeds mentioned above, let's say 70 mph as an example, although I did the test at several speeds. Notice that car is already in 6th gear based on the RPM's. How to confirm this? 1a. Shift to Sport mode, then shift to 6th gear, notice that the RPM's are the same as when in full automatic...that confirms the 6th gear rpm level. 2. Now shift back to full automatic mode at 70 mph. 3. Set cruise control - verify that rpm's don't change (they stay the same). 4. Shift to Sport mode - notice that RPM's do NOT change...stays the same...continue driving for several miles as test...rpm's stay the same, car does not downshift into 5th as long as maintaining car on a flat level, obviously a hill or incline will force the downshift to maintain cruise control desired speed. 5. Redundancy check: "double check" RPM's again by shifting upwards from sport mode to make 6 appear...notice that rpm's don't change. So...it appears that the throttle setting invoked when activating cruise control somehow overrides the automatic kickdown when shifting from automatic to sport mode... Now that we know there are some bypasses, maybe we can figure out how to bypass that annoying "Low power mode" volume cutoff when the key is out of the ignition and one wants to play the radio louder than volume 20. PJPR 2017 FFRR TD6 Former LR: 2013 RRS, 2006 RRS Last edited by PJPR01 on Sun May 17 2009 4:13am. Edited 2 times in total |
Great work! |
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 ![]() ![]() |
Just to add to PJPR01's test above, if you are already in Sport Automatic mode and above 80 mph (may work at lower speeds, I haven't tested it) and then switch on cruise control, it will engage 6th gear when you go downhill or on the flat and the throttle is relaxed.
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Just read this topic through and have a question bit out of the topic.
I was not able to make the first item work even with very light throttle...it just stayed in 5th all the time, maybe with a tail wind and downhill it might trick it, but I couldn't do it. On the +100 mph, a recent test here on a safe wide open stretch of highway in the desert, honestly I couldn't tell, but at those speeds, both hands are on the wheel, eyes glued to the road, I'm not sure one can even feel the minute drop, but it also doesn't seem to indicate anything on the dash (like highway mode or something to that effect would be cool). All I can say is that it loves to run at these speeds and could do so all day long. ![]() 2017 FFRR TD6 Former LR: 2013 RRS, 2006 RRS |
I'm afraid the Big Brother Speed Nannies stopped there from being a dash indication of the lowered suspension at high speed, but it does drop 20 mm and you notice the stiffer suspension on cornering (and on bumps - not in a good way!) It also feels a little more stable - especially in cross-winds.
Do not know what does this have to do with the 6th gear but I am certain that the car lowers at high speeds. On the FFRR you even used to get an indication when it did... Unfortunately the RRS and after 06 FFRR do not indicate it anymore but still do drop 20mm |
That's because from 2007 MY FFRR got the D3/RRS suspension and dropped at 100 mph instead of the previous 60 mph. So no longer legal speeds in most parts of the World and we couldn't have people trying to get the indicator to show in the dash at 100 mph now, could we? ![]() |
Hmmm, will try it next time I am over in SK and take a pic what message do I get on dash |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
Just back from a jaunt to those unrestricted autobahns |
Pics? PJPR 2017 FFRR TD6 Former LR: 2013 RRS, 2006 RRS |
It will be a few days before I'm back in Germany, |
