Home > General > WET CARPETS |
Have you had a windscreen replaced? If so they damaged the filter box when replacing the screen. If no windscreen replaced it will possibly be a drainage hose that has come detached under the glove box. Do a search and there is plenty of info on this. 2005 Zambezi TDV6 - Gone but not forgotten
Tue Apr 14 2009 6:43pm |
dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450 |
We have that problem in our 2 cars... in Volvo cabrio, and in XK - in both cases it was caused by the broken tube from some air condition... dont know exactly what. But it is on 90% connected with air condition.
Tue Apr 14 2009 6:46pm |
wullie Member Since: 28 Mar 2009 Location: Ayrshire Posts: 81 |
Thanks Guy's that was very helpfull I have printed out the SB's and now I know where to start, I will check it out and let you know what I find. I have only had the car for 2-3 weeks windscreen looks original.
Tue Apr 14 2009 7:43pm |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
weak bladder? |
Tue Apr 14 2009 9:01pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Also check NSF A pillar external trim w or w/o wndscreen change if it is loose this could cause ingress - Bobby will turn up soon with SB detailing the washers that were changed to improve water tightness |
Tue Apr 14 2009 10:32pm |
What? You mean this...? http://www.rrsport.co.uk/gallery/albums/us...illar2.pdf Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Tue Apr 14 2009 11:58pm |
Wed Apr 15 2009 8:28am |
That's the one |
Wed Apr 15 2009 9:33am |
Hi Guy's
Wed Apr 15 2009 9:22pm |
I think am gonna need help from you guy's, after further investigation I have found the drain tube that runs down the n/s 'A' post. it must exit out behind the fuse box and come out the lower bulkhead behind the plastic wheel arch cover. When testing with water on the sunroof the water runs down all the wiring behind the fuse box and below the carpet. The thing is I can just only touch the tube with my fingers, I cant see where it goes or even feel where it should go. Looks like I might have to strip out the lower half of the dash/glove box and maybe the fuse box. any ideas would be much appreciated,
Fri Apr 17 2009 7:03pm |
Thats it sorted Guy's
Thu Apr 23 2009 9:14pm |
Well done Wullie and thanks for the update
Fri Apr 24 2009 8:53am |
Glad it worked out well for you and thanks for posting the update. Malaysia Boleh!
Fri Apr 24 2009 10:48am |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 374 |
I think this has happened to me today
Thu Dec 30 2010 8:40pm |
