Home > General > brake pads 99.5% worn, except....
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
hmmm. Continuing my ongoing sceptism of local dealer, I was informed by them that my brake pads (F+R) were 99.5% worn with "tens not hundreds" of miles left on them. Politely declined the offer to replace them.
On closer inspection there appears to be a good 3-4mm of pad material left (F+R), at least on the outer pads. And the pad wear indicator has not come on yet, which I would expect if they wer 99.5% worn.
1. how does the pad wear indicator actually work? I'd love to see Bobby pull out one of his links...
2. is there a reliable visual way to estimate pad wear?
3. car has 20k on the clock and is driven enthusiastically.. what sort of lifespan are people getting with pads? I bought her at 15k and dont know if pads had been changed previously
thanks
Post #222131 Mon Apr 13 2009 3:03pm
bex
The pads simply have embedded wires in the material and once they wear to expose the wires it makes contact with the disc and creates a circuit which illuminates brake pad warning light.
Post #222137 Mon Apr 13 2009 3:14pm
MAW
The sensor is not in the pads it sits along side the front left pad and rear right (or other way around - but not each corner) - it does wear as the pads wear and either shorts closed or wears open in electronic terms. The dealer is BS'ing with 10's not 100's comments - IIRC my light came on and then you potentially have 600-1000 miles of use left depending on driving style. The light will (or used to ) flicker on for a while until the sensor becomes adequately worn, i had two sets on my last RRS in around 41K - that was with heavy wear....
Try another dealer or call his bluff he is talking BS IMO
Post #222142 Mon Apr 13 2009 4:21pm
MAW
Also - catch it early and you can save on not needing new sensors (around £7 &£12 ea IIRC) front and rears pads were around £110, again IIRC - a DIY job if confident?
Post #222143 Mon Apr 13 2009 4:24pm
rrsboy
thanks for the very useful info MAW. will update you with progress.. yes could do DIY if necessary, last time i did was on a 1989 ford fiesta XR2 mind..... Smile
Post #222150 Mon Apr 13 2009 6:28pm
MAW
Pm if you need more mate
Post #222178 Mon Apr 13 2009 10:20pm
