![]() | Home > General > brake pads 99.5% worn, except.... |
bex Member Since: 24 Mar 2008 Location: Abingdon Posts: 179 ![]() |
The pads simply have embedded wires in the material and once they wear to expose the wires it makes contact with the disc and creates a circuit which illuminates brake pad warning light. |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
The sensor is not in the pads it sits along side the front left pad and rear right (or other way around - but not each corner) - it does wear as the pads wear and either shorts closed or wears open in electronic terms. The dealer is BS'ing with 10's not 100's comments - IIRC my light came on and then you potentially have 600-1000 miles of use left depending on driving style. The light will (or used to ) flicker on for a while until the sensor becomes adequately worn, i had two sets on my last RRS in around 41K - that was with heavy wear....
Also - catch it early and you can save on not needing new sensors (around £7 &£12 ea IIRC) front and rears pads were around £110, again IIRC - a DIY job if confident? |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
thanks for the very useful info MAW. will update you with progress.. yes could do DIY if necessary, last time i did was on a 1989 ford fiesta XR2 mind..... |
