![]() | Home > Technical > pdc module location anyone? |
| colintks Member Since: 15 Mar 2008 Location: west bromwich Posts: 17
Hi guys,Can anyone tell me where the pdc module is located.I've had a problem with pdc on front for a week now, |
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944
It's on the LH rear quarters of the car, behind the side trim panel in the trunk/boot. It's a small rectangular module attached to the frame with 2 retaining screws and with 3 electrical connectors on the bottom, should be in plain sight when you remove the trim panel. It's one of the few electronic modules in the car that should not require software uploads, diagnostics, programming and exorcisms after you hook it up, it should be "plug and play"... |
Hey Bobby, I think that removing the side trim panel is more involving than replacing that module... |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
Yes, umbertob, quite a bit of work involved! |
Thank's guy's,stripped the car down today.Exchanged the module but still playin up, |
Bummer. If it makes you feel any better, I am having the same problem with one of my rear PDC sensors, although I know exactly why it's starting to act up - it's my fault for removing the tips off my Overfinch exhaust when I go off-roading and then being too lazy to put them back on when I get back. The hot gases from the shortened exhaust ends are causing the two sensors in their proximity to slowly "melt" (as well as a portion of the lower bumper...) |
Hey umbertob, was the directions to remove the side panel satisfactory? |
| All times are GMT |
