Home > General > Max ground clearance
diamond
Greece 2009 Range Rover Sport TDV6 SE Alaska White
I know that D3 has a maximum ground clearance of 31 cm using all the gimmicks of the air suspension.
What about the RRS?
Post #211035 Wed Feb 11 2009 11:45pm
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Looks like about 31cm to me. I think the suspension system on the D3 and RRS are the same - with the extra extended mode effecting a lot of clearance. I didn't get underneath and measure it though..... RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #211057 Thu Feb 12 2009 8:43am
diamond
I thought because initially the RRS is 1.5 cm lower then the max ground clearance will be also lower.
In the manual doesn't say exact numbers just that it will be 5 cm higher in offroad setting which means 22.7 total ground clearance which seems too low
Post #211070 Thu Feb 12 2009 9:11am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Range Rover Sport Exterior Dimensions Item
Width with mirrors
2,170mm
Width with mirrors folded
1,983mm
Height (Standard ride height)
1,784mm
Rear wheel track
1,612mm
Front wheel track
1,605mm
Wheelbase
2,745mm
Length
4,788mm
Approach angle (Standard ride height)
30.2
Ramp angle (Standard ride height)
20
Departure angle (Standard ride height)
26
Obstacle clearance (Standard ride height)
172mm
Wading depth
700mm
Weights, kg
Feature TDV6
TDV8
Supercharged
Unladen total
2455
2675
2572
Laden gross vehicle weight
3070
3175
3125
Max front axle
1470
1540
1470
Max rear axle
1710
1710
1710
Towing (towing pack optional), kg
Feature TDV6
TDV8
Supercharged
Unbraked trailer
750
750
750
Maximum Towing
3500
3500
3500
Luggage capacity and interior space
( - Not applicable)
Feature
Height (mm)
Width (mm)
Length (mm)
Behind rear seats - enclosed luggage space
943
1221
991
Rear seats forward (behind Row 1)
943
1221
1754
Maximum front headroom with fixed roof
977
977
977
Maximum front headroom with sunroof
1000
1000
1000
Loadspace volume (rear seats upright)
958 litres
Loadspace volume (rear seats folded)
2013 litres
Exterior space
( - Not applicable)
Feature
Height (mm)
Ground clearance (off-road height)
227
Wading depth (mm)
700
Discovery Exterior measurements (mm) Item Dimensions[b]
2009
Width with mirrors out
2190
Rear wheel track
1612.5
Front wheel track
1605
Wheelbase
2885
Length
4835
Minimum height (mm) Roof option Coil suspension
Air suspension
Fixed roof
1887
1837
Alpine roof
1882
1832
Roof rails
1891
1841
Integrated phone antenna
1940
1890
Interior dimensions (mm) Head room Dimensions
1st row
1020 (1027 with Alpine roof)
2nd row
1043 (1073 with Alpine roof)
3rd row
983 (1018 with Alpine roof)
Leg room
1st row
1078
2nd row
955
3rd row
923
Shoulder room
1st row
1503
2nd row
1508
3rd row
1087
Load capacity (mm) Load space length behind: Dimensions
1st row
1950 7 seat (1831 5 seat)
2nd row
1124 7 seat (1108 5 seat)
3rd row
338 7 seat
Turning circle (m)
Dimensions
Kerb to kerb
11.45
Wall to wall
11.8
Wading depth (mm)
Dimensions
Maximum wading depth (Air suspension only)
700
Normal wading depth
600
[/b]
Discovery is slightly wider and longer than RRS, can't find departure angles and off road height though for Disco.
Post #211091 Thu Feb 12 2009 10:20am
lespes
Here we are
disco 3 off road heights
Approach Angle (degrees)(Standard/Air Suspension off road) 32.2/37.2 32.2/37.2 32.2/37.2 32.2/37.2
Departure Angle (degrees) (Standard/Air Suspension off road) 26.7/29.6 26.7/29.6 26.7/29.6 26.7/29.6
Ground Clearance (Standard /Off Road Height (air sus) ) (mm) 185/240 185/240 185/240 185/240
Post #211103 Thu Feb 12 2009 10:34am
lespes
1.3 cm difference but the disco has a longer wheelbase
Post #211105 Thu Feb 12 2009 10:37am
diamond
Yes I know that numbers.
The think is that I also know that D3 can go up to 31 cm with all the suspension extended (super extended mode)
Is that case also for RRS? Or because is more tarmac oriented has any limitations?
Post #211176 Thu Feb 12 2009 11:38am
Super Extended mode is also on the RRS but would at a guess say it's 1.3 cm lower. The Super extended Mode is automatic - you can not select it. 2005 Zambezi TDV6 - Gone but not forgotten
Post #211178 Thu Feb 12 2009 11:44am
Tim in Scotland
If you need more offroad height then get a set of AT tyres or MTRs and they will give you an extra cm or two, but if you are worried about 1-2cms of height offroad then you are not enjoying your driving. Better to fit a Mantec
sump guard (there's a slightly used one for sale in the For Sale and Wanted section Whistle Whistle ) and slide around on it. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #211231 Thu Feb 12 2009 2:54pm
Leo
Kenya
The only reason for the difference between D3 and RRS ground clearance is that the D3 is supplied with taller profile tyres. Thumbs Up
Post #211251 Thu Feb 12 2009 4:14pm
diamond
My concern started because I didn't know the exact figures for RRS and because most people consider RRS as tarmac oriented 4x4 while D3 is more offroad oriented.
Of course I have no problem with 1-2 cm. I used to have a Cherokee XJ with 21 cm differential clearance and went everywhere. So if I get the RRS with at least 23 cm clearance I can go anywhere too with the right protection.
Post #211257 Thu Feb 12 2009 4:33pm
Trust me the RRS can go wherever the Disco3 can go. 2005 Zambezi TDV6 - Gone but not forgotten
Post #211292 Thu Feb 12 2009 5:45pm
Jonny Fresh
Into a caravan park?
To a carboot sale?
To a tarmac and bareknuckle fighting convention?
Post #211309 Thu Feb 12 2009 6:35pm
diamond
To a carboot sale?
Rolling with laughter
It's the same everywhere. When I had the Cherokee, the Wrangler owners thought that they were the only real Jeepers
Post #211321 Thu Feb 12 2009 7:51pm
McBunny
Germany 2006 Range Rover Sport TDV6 HSE Bonatti Grey
@Jonny:
Rolling with laughter Rolling with laughter Rolling with laughter
@diamond:
Yes, but now you are on the better side! Thumbs Up Bow down
But aren't Wrangler-drivers pimps (with a bad income because if the income was good they would drive a Viper Rolling Eyes ) while Cherokee-drivers are football-moms? Mr. Green
Laughing
The difference with RRS and D3 is different: I think, nobody here would tell, the D3 is not a good Landrover or 4x4, it's just that, well, look at the D3 (and it's owners Whistle Mr. Green ) and then have a look at the RRS (and it's owners Cool ).... Rolling Eyes Twisted Evil
Laughing Laughing Laughing RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #211398 Fri Feb 13 2009 11:21am
