![]() | Home > General > Max ground clearance |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
diamond Member Since: 09 Feb 2009 Location: Dusseldorf, Germany Posts: 217 ![]() ![]() ![]() |
I thought because initially the RRS is 1.5 cm lower then the max ground clearance will be also lower.
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Range Rover Sport Exterior Dimensions Item
Here we are
1.3 cm difference but the disco has a longer wheelbase |
Yes I know that numbers.
Super Extended mode is also on the RRS but would at a guess say it's 1.3 cm lower. The Super extended Mode is automatic - you can not select it. 2005 Zambezi TDV6 - Gone but not forgotten
If you need more offroad height then get a set of AT tyres or MTRs and they will give you an extra cm or two, but if you are worried about 1-2cms of height offroad then you are not enjoying your driving. Better to fit a Mantec
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
The only reason for the difference between D3 and RRS ground clearance is that the D3 is supplied with taller profile tyres. |
My concern started because I didn't know the exact figures for RRS and because most people consider RRS as tarmac oriented 4x4 while D3 is more offroad oriented. Of course I have no problem with 1-2 cm. I used to have a Cherokee XJ with 21 cm differential clearance and went everywhere. So if I get the RRS with at least 23 cm clearance I can go anywhere too with the right protection. |
Trust me the RRS can go wherever the Disco3 can go. 2005 Zambezi TDV6 - Gone but not forgotten
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
Into a caravan park? To a carboot sale? To a tarmac and bareknuckle fighting convention? |
![]() It's the same everywhere. When I had the Cherokee, the Wrangler owners thought that they were the only real Jeepers |
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 ![]() ![]() ![]() |
@Jonny:
