![]() | Home > Technical > Can this be done ??? |
Rupert Member Since: 13 Mar 2006 Location: Here !!! Posts: 1194 ![]() ![]() |
I think though, I’d test that first with someone left sitting inside.
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 ![]() ![]() ![]() |
Unnecessary quote removed
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
That's why i think i'll try the reverse of it first, start with one key door closed and attempt a manual lock from the passenger door (assuming the manual function operates central locking and not just that door) |
Who's Wooly hat? 2005 Zambezi TDV6 - Gone but not forgotten 2009 Alaska TDV8 - Gone and much missed. ![]() WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
How can i be sure the FBH is working |
Puffs of smoke from under the front of the car is the easiest tell tale sign in the cold weather. |
'Puffs" More like a storm cloud appearing on the n/s front wing! 2005 Zambezi TDV6 - Gone but not forgotten
Yes i had that on the old one - very obvious - this one isn't though - but there must be a definitive way to say working or not... |
Put your hand near the FBH and you should feel the heat. DON"T TOUCH THE THING! 2005 Zambezi TDV6 - Gone but not forgotten
Is that how you got Keira to pose VA? |
All the time or just first thing in the am? What temp does it kick in at? Where is Bobby when you need him ![]() ![]() |
I don't believe it runs all the time, and it only kicks in below 3degC |
As the fat one says. 2005 Zambezi TDV6 - Gone but not forgotten
