![]() | Home > Technical > Can this be done ??? |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
I wanted to run the car this morning to get it defrosted and warmed ready - started it up with one key and wanted to lock it with the other to secure it - just in case....
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459
Get a timer on the FBH with a GSM unit and you can get the car ready by phone. It'll not heat the cabin up but as soon as you get in the car and start it hot air will come out of the vents. 2005 Zambezi TDV6 - Gone but not forgotten
| JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898
But with the FBH shouldn't it heat up quick anyway? RRS TDV6 Gone but still around
Even if you could all you'd have to do is smash the window and drive off
MAW - here you go. http://www.disco3.co.uk/forum/topic15454.html or you can get 10forcash to do it for you. Fitted about £400+VAT 2005 Zambezi TDV6 - Gone but not forgotten
Thanks VA |
It's true tho MAW
Interesting read - i think i will see if the manual lock from the passenger side works first though |
Mate try this
Jay - all diesels with a FBH I think. 2005 Zambezi TDV6 - Gone but not forgotten
I'd like to get this fitted to my van guess it can be fitted to that as well? RRS TDV6 Gone but still around
| highbridgeflyer Member Since: 06 Aug 2006 Location: Midlands Posts: 113
Not sure if the XS has a FBH..... |
| crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289
you could always start her up, open the drivers window, close the door, lock the doors through the open window, close the window with the confort closing windows and then use the other key to open it later. you might have to use the other key manually though with the lock on the passengers side |
