Home > Technical > MORE KNOCKING SUSPENSION !!!!
BIG BAD RANGE
Evening Gents , yes here is another , my RR Sport TDV8 HSE 08 Overfinch , has this KNOCKING from the front suspension , and it had got worse , mine noe has done 6000miles.
Spoke to dealer , LR of Canterbury , again said its normal , and once over (i think 27mph) the ARC cuts in and stops the noise , well today i was nearing 40mph and still KNOCK KNOCK !!
Going to call them on Monday to book it in , i read that by taking the "fuse" out relating to this cures the KNOCKING anyone tried it ?
Let me know , once you have stopped munching on that turkey sandwich !!
Post #201987 Sat Dec 27 2008 10:14pm
Some dealers will help others simply wash their hands. If your present dealer looks like the latter take it to another dealer. 2005 Zambezi TDV6 - Gone but not forgotten
Post #201991 Sat Dec 27 2008 10:58pm
BIG BAD RANGE
SUSPENSION KNOCK
Does by taking the ARC fuse out , stop the knocking ? and how will the car drive / handle with the ARC not working ?
thanks
Post #201992 Sat Dec 27 2008 11:10pm
The whole knocking problem can be a number of things or a combination of them. Yes taking the fuse out seems to work for some but it's not a solution. 2005 Zambezi TDV6 - Gone but not forgotten
Post #202002 Sun Dec 28 2008 10:50am
BIG BAD RANGE
Morning , well just removed the 15amp fuse relating too the ARC system , and the results are a disappointing
No difference , yes it stopped the "knock" sound if you moved the steering left to right very fast , but that was it !!!
So i guess im gonna have to go to the dealer Sad Big Cry
Post #202011 Sun Dec 28 2008 11:58am
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
how noticeable is this knocking RRS are afflicted with?
Was in the isle of man last week and noticed that there was a knocking when going over small bumps etc - but sounded more like there was play in the suspension? Is this the dreaded knocking or something else?
Post #202080 Sun Dec 28 2008 7:42pm
BIG BAD RANGE
Well im going to call my dealer in the morning , and if i am right guys request the following
1. replace the two antiroll bar stirrup bushes
2. software upgrade "dvd 105 patch file 3"
3. new design ball joint ?
4 anti roll bar ?
Then it may stop this knocking , which has got worse over this week !!
Post #202084 Sun Dec 28 2008 7:58pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
People, removing the fuse is not a solution, yes it may reduce or subdue the knocking noise somewhat, but you will be effectively be removing the cornering capabilities of the car, cue FFRR.
If you do not mind the wallowing effect, knock yourselves out and remove it.
A more pro active approach would be to collectively do something, that something I am unsure off. Big Cry
These links sum up the general feeling and also offer insight into the solutions offered by various dealers etc.
http://www.rrsport.co.uk/forum/topic7227.html
http://www.rrsport.co.uk/forum/topic10650.html
In summary and not to be the bearer of bad news, there is no solution currently, there is however conclusive evidence that the problem is becoming more and more widespread. The boys and gals at LR are playing the cards very close to their chests on this one and we still do not have any forthcoming date for this most irritating and embarrassing of noises. Big Cry L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #202086 Sun Dec 28 2008 8:00pm
Bobby
try this...
http://www.rrsport.co.uk/gallery/albums/us...letin4.pdf
or better still, make your dealer go through this...
http://www.rrsport.co.uk/gallery/albums/us...gnosis.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #202879 Fri Jan 02 2009 7:25am
Josh
Yep.....starts like that and gets progressively worse Exclamation TDV6 - gone
TDV8 - gone
Post #203203 Sun Jan 04 2009 11:39am
Wozz
Anyone with an 09 model suffered this?
I am desperately hoping the issue has been resolved in newer models but suspect this may not be the case. WINNER - 2009 Best Newcomer Award
'09 TDV6 XS Stornaway Grey
'06 BMW 730 D SE (Gone)
'08 A4 TDi SLine Avant (Gone)
Large pack of Flake Cakes (Gone)
6 pack of Guiness (Gone)
Post #203204 Sun Jan 04 2009 11:44am
Josh
I some how think not yet.
I understand LR intend to put the DR system on the next lightweight aluminium version of the FFRR and I suspect that will be the first time we will see this problem engineered out of it.
Can't immagine they are going to produce a FFRR with an intended characteristic knocking suspension system..... Whistle
As to when the RRS will get sorted well............... Whistle TDV6 - gone
TDV8 - gone
Post #203207 Sun Jan 04 2009 11:59am
Wozz
So I just have to keep my fingers crossed and hope I don't have an affected model I guess.
I'm not usually that lucky though. WINNER - 2009 Best Newcomer Award
Post #203210 Sun Jan 04 2009 12:06pm
Josh
Sorry I think that is the case at the moment. But perhaps someone in the know will post a more hopeful answer before you make your decision.
Having said that this an annoying problem, I still really love driving this car even with the fault. TDV6 - gone
TDV8 - gone
Post #203214 Sun Jan 04 2009 12:09pm
Wozz
Alas the choice is made and I only have a few days left befor ethe vehicle is delivered.
Ah well I will wait and see - thanks for the heads up - I just wish I would have joined this forum sooner so i would make a fully informed buying decision. WINNER - 2009 Best Newcomer Award
Post #203225 Sun Jan 04 2009 12:32pm
