![]() | Home > Technical > Looks like my clutch is dying! |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496
Im going to do the 4ltrs drain and refill run for a few miles , then drop the sump and add a new one with some more new oil. |
UPDATE
| BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324
told you....
Ive done my oil drain and refill today, ill leave it like that for now and may be change the sump/filter next service with new oil again.
Yes ill let you know if it made any difference.
Does it have a drain plug , I had it in mind you had to remove the sump to drain the oil.
It has a drain plug m8,see the pdf in the above post and it has some nice pictures in also |
| PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355
I agree Nutty..but if that's all they are charging you for the fluid change that would be a surprise. Here in the U.S. the cost of labor and fluid is upwards of $450 just for the transmission and an additional $250 or so for the differentials- I checked just 3 months ago at the 50K service on the transmission and differentials. The only one I had done that was reasonable at $100 was the transfer case. At any rate, I do think the transmission must have a longer extended warranty period than the original 4/50. PJPR 2017 FFRR TD6 Former LR: 2013 RRS, 2006 RRS |
| Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355
well done pete. you have just reduced the chances of a burn up of the forward drive clutches, and the lock-up clutch by a mile. You are right about the fluid amount when draining, don't be worried about that because there is between a half and one litre of fluid left in the torque convertor that will not drain back, (sits in the lower half - obviously) Regards Nigel. You don't stop playing because you get old, You get old because you stop playing. 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
Thanks Nutty Nige for the reasurance,
It will not do any harm - I would but then I am real fussy about it - that is the only way to get most of the old stuff out. You don't stop playing because you get old, You get old because you stop playing.
Thanks Nige , ill do it again after a few miles.
| All times are GMT |
