![]() | Home > General > Low Coolant Warning |
There have been reports of a faulty coolant level sensor.... replacing this fixes the problem. Otherwise could just have been part of owning a RRS - keep an eye on it and take it in to the dealer if it starts happening regularly |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368
Thanks shmoogle, booking in for some other software downloads in next few weeks so i ill ask them to check / change sensor |
You need to get the expansion bottle replaced - warranty job. 2005 Zambezi TDV6 - Gone but not forgotten
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
I have heard both of split bottles and faulty sensors - keep an eye on the level until you are next at the stealer when warranty should take care of it... |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
In the early days they used to replace the whole bottle but recently, if there's no signs of coolant loss and the sensor float has not sunk, it is not necessary to replace the coolant tank. It is possible that the engine low level coolant switch (located at the bottom of the coolant expansion tank) may be at fault.
| XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894
the low coolant thing is a Jaguar V8 engine specific problem - sensor is to sensible for a little water loss - i have had this with all my V8 Jags...
But the TDv6 is a Peugeot/Citroen/Ford engine modified to suit Land Rover's requirements Angel.................... it isn't a Jag engine 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Maybe the coolant bottle itself is a Jag-sourced part.... they were all Ford/PAG parts at the end of the day I suppose. |
Thanks to all, booked in next week, will post regarding outcome. |
Well had the problem looked at and advised that the coolant was low ( not sure how as i have been checking it since last week) they claimed that the there was some air in the system and they have bled it and it should now be OK, although i did ask why this had not been spotted at the service it allegedly received prior to my delivery, ill wait and see how it goes from here. |
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293
Bet you a tenner that you get a low coolant warning again.... |
I had several Low Coolant warnings over a weekend after the FBH was fitted to my TDv6, I called out LR Assist and they could find nothing wrong. On the Monday i took the car into the local dealers who had had to drop some coolant out to fit the heater........................ they topped the system up and I never had a warning again 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| SteveNorman Member Since: 18 Sep 2008 Location: somerset Posts: 7
Hi, The sensor is part number PCJ500030 £ 2.94+vat!. it's fitted to the bottom of the expansion bottle.
| All times are GMT |
