| RRSPORT.CO.UK | ||
|  | Home > General > Low Coolant Warning |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | There have been reports of a faulty coolant level sensor.... replacing this fixes the problem. Otherwise could just have been part of owning a RRS - keep an eye on it and take it in to the dealer if it starts happening regularly   | ||
|  Fri Sep 12 2008 7:59am |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368      |
 Thanks shmoogle, booking in for some other software downloads in next few weeks so i ill ask them to check / change sensor   | ||
|  Fri Sep 12 2008 8:05am |
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459    | You need to get the expansion bottle replaced - warranty job. 2005 Zambezi TDV6 - Gone but not forgotten
|  Fri Sep 12 2008 9:52am |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104      | I have heard both of split bottles and faulty sensors - keep an eye on the level until you are next at the stealer when warranty should take care of it... | ||
|  Fri Sep 12 2008 10:22am |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | In the early days they used to replace the whole bottle but recently, if there's no signs of coolant loss and the sensor float has not sunk, it is not necessary to replace the coolant tank. It is possible that the engine low level coolant switch (located at the bottom of the coolant expansion tank) may be at fault.
|  Fri Sep 12 2008 11:11am |
| XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894    | the low coolant thing is a Jaguar V8 engine specific problem - sensor is to sensible for a little water loss - i have had this with all my V8 Jags...
|  Fri Sep 12 2008 11:31am |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | But the TDv6 is a Peugeot/Citroen/Ford engine modified to suit Land Rover's requirements Angel.................... it isn't a Jag engine 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Fri Sep 12 2008 11:57am |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | Maybe the coolant bottle itself is a Jag-sourced part.... they were all Ford/PAG parts at the end of the day I suppose.  | ||
|  Fri Sep 12 2008 12:06pm |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368      | Thanks to all, booked in next week, will post regarding outcome. | ||
|  Fri Sep 12 2008 12:51pm |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368      | Well had the problem looked at and advised that the coolant was low ( not sure how as i have been checking it since last week) they claimed that the there was some air in the system and they have bled it and it should now be OK, although i did ask why this had not been spotted at the service it allegedly received prior to my delivery, ill wait and see how it goes from here. | ||
|  Fri Sep 19 2008 4:48pm |
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293    | Bet you a tenner that you get a low coolant warning again....  | ||
|  Fri Sep 19 2008 6:37pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | I had several Low Coolant warnings over a weekend after the FBH was fitted to my TDv6, I called out LR Assist and they could find nothing wrong. On the Monday i took the car into the local dealers who had had to drop some coolant out to fit the heater........................ they topped the system up and I never had a warning again 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Fri Sep 19 2008 7:04pm |
| SteveNorman Member Since: 18 Sep 2008 Location: somerset Posts: 7    | Hi, The sensor is part number PCJ500030  £ 2.94+vat!. it's fitted to the bottom of the expansion bottle.
|  Fri Sep 19 2008 9:14pm |
| Posting Rules
 for long drive north and after about 4 miles received warning that the coolant level was low, this stayed in the display under the information screen for about 30 seconds and then disappeared, kept an eye on the temp gauge and all was normal and no further warnings during my 200 mile trip, any ideas what may be the cause and yes i have checked the coolant level!!!
