![]() | Home > General > Which is the 'right' speed |
| Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586
The car's speedo is right....it is much more accurate than a speed camera detector. |
| npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716
i have had this on my portable satnav too
| bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336
But if that is the case, why does 40mph on the ACC not equal 40mph on the speedo? |
| rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551
Your GPS is likely to be your true speed. Both the cruise control and speedo will have a safety factor to a) eliminate litigation in speeding court cases and b) to allow for variables such as tyre wear. Basically they are both driven from the circumference of the tyres. The GPS computes the time a distance is travelled in and therefore has no variables. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
| JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898
My one tell's me i'm doing 70 and the speedo will say 75/76 = 10%? RRS TDV6 Gone but still around
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293
It's not. GPS is very accurate, to within 0.2 miles per hour. Speedo is likely incorrect. Legally, the speedo in the UK must not underestimate, but believe it or not, may overestimate speed (I think by as much as 10%). My ACC when set to 80, runs at around 78 on the speed. Most annoying. 2022 P440e AB |
Well they give 10% for speed cam's so the speeto must be set plus 10% RRS TDV6 Gone but still around
| Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435
I mentioned this to my dealer after getting the car, speedo = 80km/h ACC =82km/h GPS = 78km/h
Are you get a speed reading off LR GPS? I.E. The Nav screen? 2022 P440e AB |
nope, from either a Garmin 45XL GPS or a TomTom Go910, tried both with same result. Sons of dogs come hither and get flesh
Didn't know I could do that one - in the 4*4 screen? Will have a look through the manual and try and compare them all |
I don't think you can get the speed off the LR screen. That is why I asked. |
I disagree....GPS speed readings vary from GPS units, I've seen 2 different sat navs in one car give 2 different speeds, Satellite strength varies by location, weather, topography etc....most car speedos are accurate to a tollerance of +1% assuming correct tyre pressure. Also read this about the failure of GPS speed reading........ http://continuouswave.com/ubb/Forum6/HTML/001066.html |
Jay - No wonder your 0-62 times are the same as a TDV8 |
