Home > General > Which is the 'right' speed
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
Cruise control set to 40, typically will be 43/44 on the speedo
Just had a camera detector fitted, and the speed reading on this matches the speedo reading
When im in a 40 specs zone, i now have to put the cruise to about 37 to be on 40 on the camera detector and therefore for me not to want throw the beeping thing out the window
My question though is I thought the detector would be on GPS and therefore 'true' speed, and so would tie in with the cruise control setting, yet the cruise is either too fast, or the detector is under reading?
So which is right?!
Post #171250 Mon Jun 02 2008 10:22am
Jonny Fresh
The car's speedo is right....it is much more accurate than a speed camera detector.
Post #171253 Mon Jun 02 2008 10:32am
i have had this on my portable satnav too
I have heard a cars speedo is calibrated to within a certain percentage, so might not be totally true. the satnav been GPS should give you a true speed, but i presume would depend on how precise the GPS is in satnavs, as i have also heard that civillian satnav have a certain amount of wobble in them.
You could always do a measured mile, and time it at a set 40mph speed and work out how long it should have taken you to do it a 40 mph as see which is closest.
Post #171254 Mon Jun 02 2008 10:33am
bermyandy
But if that is the case, why does 40mph on the ACC not equal 40mph on the speedo?
Post #171257 Mon Jun 02 2008 10:48am
rrsjo
Your GPS is likely to be your true speed. Both the cruise control and speedo will have a safety factor to a) eliminate litigation in speeding court cases and b) to allow for variables such as tyre wear. Basically they are both driven from the circumference of the tyres. The GPS computes the time a distance is travelled in and therefore has no variables. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #171265 Mon Jun 02 2008 10:58am
My one tell's me i'm doing 70 and the speedo will say 75/76 = 10%? RRS TDV6 Gone but still around
Post #171271 Mon Jun 02 2008 11:10am
PauloAmore
Scotland
It's not. GPS is very accurate, to within 0.2 miles per hour. Speedo is likely incorrect.
Legally, the speedo in the UK must not underestimate, but believe it or not, may overestimate speed (I think by as much as 10%).
My ACC when set to 80, runs at around 78 on the speed. Most annoying. 2022 P440e AB
Post #171282 Mon Jun 02 2008 12:00pm
Well they give 10% for speed cam's so the speeto must be set plus 10% RRS TDV6 Gone but still around
Post #171283 Mon Jun 02 2008 12:03pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
I mentioned this to my dealer after getting the car, speedo = 80km/h ACC =82km/h GPS = 78km/h
Now change the wheels to 255/55 19" MT/R and speedo = 80km/h, ACC = 82km/h GPS = 80km/h Thumbs Up Sons of dogs come hither and get flesh
Clan Cameron
Post #171285 Mon Jun 02 2008 12:17pm
PauloAmore
Scotland
Are you get a speed reading off LR GPS? I.E. The Nav screen? 2022 P440e AB
Post #171286 Mon Jun 02 2008 12:21pm
Alicatt
nope, from either a Garmin 45XL GPS or a TomTom Go910, tried both with same result. Sons of dogs come hither and get flesh
Clan Cameron
Post #171287 Mon Jun 02 2008 12:24pm
bermyandy
Didn't know I could do that one - in the 4*4 screen?
Will have a look through the manual and try and compare them all
Post #171288 Mon Jun 02 2008 12:24pm
PauloAmore
Scotland
I don't think you can get the speed off the LR screen. That is why I asked. Thumbs Up 2022 P440e AB
Post #171291 Mon Jun 02 2008 1:05pm
Jonny Fresh
I disagree....GPS speed readings vary from GPS units, I've seen 2 different sat navs in one car give 2 different speeds, Satellite strength varies by location, weather, topography etc....most car speedos are accurate to a tollerance of +1% assuming correct tyre pressure.
Also read this about the failure of GPS speed reading........ http://continuouswave.com/ubb/Forum6/HTML/001066.html
Post #171292 Mon Jun 02 2008 1:17pm
rrsjo
Jay - No wonder your 0-62 times are the same as a TDV8 Rolling with laughter Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #171313 Mon Jun 02 2008 4:11pm
