Home > Maintenance & Modifications > Engine Blown up |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 184 |
Nige,
Fri Apr 25 2008 10:37am |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 |
No it shold not. You just have a recrod of when it was last plugged in or up-dated because you are writing the data over the top. It erases the current map before it writes the new one.
Tue Apr 29 2008 10:16pm |
so say a problem developed with the vehicle and you then had the ecu re-flashed with the original map prior to returning the vehicle for warranty work, then LR could if they wished, check the vehicle ecu and this would then show it had just been re-flashed - and un less you could prove this was done by a LR main agent then you could be into a problem with them declining a warranty claim. Not trying to be difficult or anything, but it seems to me even if a a chip cannot be detected, the fact that an ECU has been re-flashed to revert to the original tune will give the game away and could result in a warranty claim being declined. In reality then all these claims from chip companies about them being invisible / undetectable is totally irrelevant as LR if they are determined to get to the bottom of a major problem / component failure will either see the chip by interogating the ecu or simply by the fact that the ecu has just been re-flashed. are my assumptions correct?? please don't misunderstand my motives as I am also looking at having a vehicle done. Its the misleading claims by some chip tuners that I feel are a little naughty and are leading some vehicle owners into unchartered waters which could result in vast bills if a warranty claim is declined due to the vehicle either being chipped or a problem with a re-flash not being undertaken by a main agent. |
Wed Apr 30 2008 2:40pm |
I will send you a pm to explain it to you You don't stop playing because you get old, You get old because you stop playing.
Wed Apr 30 2008 6:05pm |
Without you implicating anyone Nige, it would be valuable for the forum if you shared your explanation with the rest of us - this is an interesting topic and would benefit from some qualified opinion
Thu May 01 2008 11:13am |
Just din't want to bore you.
Thu May 01 2008 7:31pm |
Thanks mate - always good to have techie info for those that need that level of detail
Fri May 02 2008 9:49am |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
Potentially more common issue is that if the tune is worth the money then any LR tech taking it for a drive will know it has been remapped within 10yds...no computer required. If he can't tell the difference over a std then the tune wasn't worth the money IMHO.... Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Fri May 02 2008 12:03pm |
Thats right but we were discussing the issue of evidence left behind after the standard map has been loaded back in before LR Tech drives it. I think to be fair we all have valid points here but its not the issue of CAN YOU TELL that is looming on alll re-map people - its the legislation of how long will emission laws let it go on. - Let me explain. In recent visits to places like chrysler HQ in the USA, GM HQ in Germany etc - you get told what is in the pipeline, and lets face it in Europe to follow USA is the norm. They are clamping down big time on emissions in USA like you would not beleive and there are new targets that the government want ny 2009 and if not by 2010 without fail. These targets allow so few emissions that it will not be possible to use a re-map legally. Now how they intend to do it is make a new software type that is encrypted within the ECU that will make a constant measurement of the perameters used to deliver the correct engine driveability programme relevant to engine load as it is now but far more accurately. The way that is under development at the moment is to constantly measure and compare the output data that is being used within a masked processor and to check that it stays within a limit of a higher tolerence. The moment it steps outside you get limp home, reduced power, and an engine warning light or MIL lamp - as you would now with a faulty sensor. You would then get a fixed time period on , For example 10 start ups of the engine to get the fault rectified, then if the fault still exists after this time period your system shuts down completely - until it is rectified. This will not just be cars it applies to all commercials, earth movers, 70 litre CAT engines, the whole lot will have it. So the re-mapping is going to get very hard or even redundent. It is nice to see how the better reputation people like Tasmod (Rob) have gone into a diversification and expanded and I wish him all the look with his new venture, it looks superb by the pics he posted, and his choice of Dyno is superb. As I always said to the customers in my specialist workshop when the car was in the rollers - and they said to me I know its 400 BHP cause I can feel it - MY ANSWER IS - THAT LITTLE RED DIGITAL READ OUT IS YOU BHP MATE, AND WHEN THAT FIGURE LOCKS, THE BULLS##T STOPS. You don't stop playing because you get old, You get old because you stop playing. 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
Fri May 02 2008 6:31pm |
