Home > Maintenance & Modifications > Exhaust tip diameter on a TDV8?
Page 2 of 3 <123>
Jazzz
Russia 2008 Range Rover Sport TDV8 SE Buckingham Blue
rrsjo wrote:
The down turn pipe is 60mm dia on the straight portion. The pipe leading from the main exhaust to the rear box is also 60mm dia.
thanks a lot, Jo Thumbs Up
now that translates into 2,36 inches, or a little less than 2 3/8... which probably means that if we are talking about welding, the closest matching tip will be 2,5 inches or 63,5mm. I wonder what diameter the pipe that Jay fitted was... Cheers,
Andrei
Post #159027 Mon Mar 10 2008 4:48pm
The TDV6 pipe is 50mm and the SC bit is 60mm some as the TDV8 RRS TDV6 Gone but still around
Post #159036 Mon Mar 10 2008 5:50pm
Jazzz
did the tips that you fund on eBay quote diameter or just said "s/c exhaust tips"? Cheers,
Andrei
Post #159059 Mon Mar 10 2008 8:08pm
Yep the SC pipe is 60mm RRS TDV6 Gone but still around
Post #159062 Mon Mar 10 2008 8:27pm
So the SC pipe is wider than the diesel pipe.... a previous post I found said they were the same (but didn't mention any measurements).
Post #159125 Tue Mar 11 2008 11:12am
Well my guy had to make a bit for mine to fit in between the to told me the V6 pipe was 50mm and the new bit (SC) was 60mm just on going by what he told me Very Happy RRS TDV6 Gone but still around
Post #159138 Tue Mar 11 2008 12:19pm
Jazzz
as I understood TDV8 pipes = SC pipes, and TDV6 are thinner. Cheers,
Andrei
Post #159149 Tue Mar 11 2008 12:35pm
TDV8 and SC = 60mm
TDV6 = 50mm RRS TDV6 Gone but still around
Post #159150 Tue Mar 11 2008 12:36pm
So let me get this right. The TDV8 and SC pipes are 60mm diameter and the TDV6 is 50mm?
Whistle
At least now we know Wink
Post #159159 Tue Mar 11 2008 1:33pm
Think so i'll have to double check for you mate!
Wink RRS TDV6 Gone but still around
Post #159168 Tue Mar 11 2008 1:40pm
rrsjo
TDV8 definitely 60 mm outside dia.
TDV6 ? mm outside dia. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #159219 Tue Mar 11 2008 8:54pm
I'm not Censored saying it again Laughing Laughing RRS TDV6 Gone but still around
Post #159255 Wed Mar 12 2008 2:07am
rrsjo
We shall never know then Jay Yawn Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #159273 Wed Mar 12 2008 9:30am
Jazzz
looks like replacing the end part of the stock exhaust system with stainless tubing and welded-on chrome tips will improve both the sound and the looks.
gotta explore this further Cheers,
Andrei
Post #159835 Fri Mar 14 2008 8:31pm
rrsjo
You mean with something like these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...3DWatching Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #159843 Fri Mar 14 2008 9:02pm
Page 2 of 3 <123>
