Home > Technical > Low Battery
exalld
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Low Battery
Anyone had a low battery warning appear on the radio screen. It happened yesterday and this morning. I think its because I had the heated seats and windscreen etc all on at the same time but would expect it to cope with this. It ends up turning down the volume on the radio until it clears. 2007 Range Rover Sport TDV8, Stornoway Grey
Post #155499 Tue Feb 12 2008 7:21pm
Think someone else said about this before but i'm not a 100% on this RRS TDV6 Gone but still around
Post #155516 Tue Feb 12 2008 8:28pm
cyberjes
2008 Range Rover Sport TDV8 HSE Buckingham Blue
i had the same message when i started my car the first time in a week.
the music was playing but when i turned the volume up, the message showed with no change in volume.
i think it was a low battery level.
try driving for a while for the alternator to charge the battery. worked in my case.
Thumbs Up MY08 TDV8 HSE
Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock
Post #155530 Tue Feb 12 2008 9:46pm
JGreg1
United States 2006 Range Rover Sport Supercharged Java Black
I've gotten this a couple times too, seems to only happen when I try to turn up the volume while on a call right after I get in. Or at least that's when I've noticed it. But it also seems to go away pretty quickly, so as cyberjes suggested, maybe the battery just needs to charge a little.
Post #155561 Wed Feb 13 2008 2:00am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
If the engine is not yet running, that's normal. Max volume is limited to preserve juice in the battery, so if you try turning the volume up beyond 20 (with the engine running you can go all the way to 35), a battery icon and "Low Power Mode" message will briefly appear on the radio LCD.
Post #155562 Wed Feb 13 2008 2:11am
exalld
Thanks guys - as long as it not just me I feel better. Had the message again this morning when I put on the front and rear de-icer with high volume. I just need to learn to keep the volume down for that first minute. I need something to wake me up in the morning on the dreaded commute to work.
Thumbs Up 2007 Range Rover Sport TDV8, Stornoway Grey
Post #155638 Wed Feb 13 2008 2:12pm
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
It also happened to me with a brand new car I tried to check the sound of the radio and the engine was switched off and it also appeared on the screen Max Volume Limited... so donīt worry Thumbs Up 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #155662 Wed Feb 13 2008 6:08pm
