![]() | Home > Technical > Two Problems |
| Geordiehillbilly Member Since: 22 Aug 2005 Location: Newcastle Posts: 32
For the bonnet flutter check both the holding pins are engaged. I had to really slam the bonnet down to get both to lock. Works fine now. |
...and with regard to the cruise control, if it simply doesn't work then you should really visit your dealer and have them check it out. |
| canaryman Member Since: 16 Feb 2006 Location: Haag a.d amper Posts: 188
Both pins are definately engaged so I will have to take it to the dealer to get it checked.
| d3matt Member Since: 12 Jul 2005 Location: Oxfordshire, UK Posts: 730
My bonnet used to move at about 70mph and above. I tried slaming it down harder and for a long time now I haven't noticed any movement. It has seemed to fix itself. Matt
| umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944
I used to have intermittent problems with the cruise control when I first got my Sport, perhaps one time out of 10 it would not engage (or it would work fine at first but fail to reengage after I touched the brakes), all c.c. buttons would be dead, no light on the dash. After switching off the engine and turning it back on, everything would work fine again. I mentioned the problem to my dealer when I went for my 7500mi service last November, and of course they "could not reproduce" the problem at the time. I have put another 8000 miles on the car since that time, but have never experienced the issue again, and I use the feature quite a lot. File that one under "Land Rover gremlins". |
| KevinJM Member Since: 16 Dec 2005 Location: Belgrade this week Posts: 120
I had a similar problem with the cruise control. I could activate it, set it, and increase speed using the steering wheel "+" button. But if I tried to decellerate using the "-" button it switched off and would not reset or reactivate at all. Pulling in, switching off and starting again reset the cruise control but when I tried the same thing again, off went the cruise control. Ironically I was on the way to the dealer for a service when it happened. He did a software update and service, confirmed the problem with cruise control and suggested I should book it in (which I still haven't done) I've only been out on the motorways again in the last week and lo and behold, the problem has gone away!! I tend to concur with umbertob and put it down to the gremlins. |
Thanks for the replies chaps. The technician at Koenig gave me an explanation in that when the vehicle runs through its diagnostic checks the "bus" is not always quick enough to talk to the various systems and thus the system in question is not registered. It is a problem on a number of the RRS and they are looking at the software to try and come up with a solution. It goes in next monday so I will let you know what (if anything) happens
| TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927
If I ever get the chance or the bottle to do 125 in my RRS I will let you know if my bonnet 'flutters' |
| kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771
My bonnet doesn't flutter at over 100, but i've been told it tops out at under 120, so im guessing you have a SC / 4.4 V8 version mate? |
Hi Kam. I have the 2.7 diesel. I am not sure but I think we have a different engine "map" here in Germany. I have had, to be exact, 198 kmh out of it and still had more rpm to go (about quarter of the tacho).
| MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598
Why aren't all dealers like this |
| ST Member Since: 26 Oct 2005 Location: Leeds Posts: 411 |
By the sounds of it Canaryman your car doesn't have a speed limiter. Here in the UK the TDV6 D3 is limited to 110mph and the RRS 120mph.
Mine tops out at 140 mph |
MDP - you've done a typo. Your post should read 1.40mpg! 2005 Zambezi TDV6 - Gone but not forgotten
