| RRSPORT.CO.UK | ||
|  | Home > General > Wrong Trim In New TDV8 |
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459    | Trim is replaceable.  Not a reject issue. 2005 Zambezi TDV6 - Gone but not forgotten
|  Tue Dec 25 2007 9:35pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Not sure how the TPMS works but it will tell you in the owners manual how it does and how to see if it is fitted. It is a factory fit option and not standard so maybe somebody doing your spec at ordering time got the boxes mixed up. As VA says it is relatively easy to change the "wood-a-like" and not an issue for rejection. The job will require the car to be in the dealers though to replace the door cards. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Tue Dec 25 2007 10:23pm |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      |
 Its in your manual... a simple way to tell... http://www.rrsport.co.uk/gallery/albums/userpics/10024/TPMS.pdf Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award | ||
|  Wed Dec 26 2007 1:58am |
| ayates Member Since: 08 Jun 2007 Location: Houston Texas Posts: 369      | Just look at the valves on the wheels ..... if their like little metal stems then you should have TPMS.... you could also deflate a tire and then you should get a warning light come on.
|  Wed Dec 26 2007 7:26am |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Approximately how much below normal pressure do you get a warning? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Wed Dec 26 2007 9:23am |
| Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435      | My TDV8 was delivered with rohdium but I had ordered it with the straight grain walnut, , car was delivered for the 1st Oct  and just had the call from the dealer that the trim is finally in stock and the car is booked in to get it replaced. Dosn't help that I am about 1000 miles from the dealer  | ||
|  Wed Dec 26 2007 10:19am |
 Just a little write-up, Tim... System Operation Each time the vehicle is driven, the TPMS module transmits a Low Frequency (LF) (125 KHz) signal to each initiator in turn. This is received by the tire pressure sensor which transmits a Radio Frequency (RF) (315 or 433 MHz depending on market) signal to the module. This signal contains coded data which corresponds to sensor identification, air pressure, air temperature and acceleration data. The system enters 'parking mode' after the vehicle speed has been less than 12.5 mph (20 km/h) for 12 minutes. In parking mode the tire pressure sensors transmit a coded signal to the module once every 13 hours. If the tire pressure decreases by more than 1 lbf/in2 (0.6 bar) the sensor will transmit more often if pressure is being lost. The spare tire sensor transmits a signal every 13 hours in the same manner as the road wheels when in parking mode. If the tire pressure decreases by more than 1 lbf/in2 (0.6 bar) the sensor will transmit more often if pressure is being lost. As each wheel responds to the LF signal from the TPMS module, it is assigned a position on the vehicle and is monitored for the remainder of that drive cycle in that position. When the vehicle has been parked for more than 15 minutes and then driven at a speed of more than 12.5 mph (20 km/h), the initiators fire in turn for 6 seconds on vehicles fitted with 433 MHz systems or for 18 seconds on vehicles fitted with 315 MHz systems in the following order: Front left 6 second pause (for the TPMS module to detect a response from the tire pressure sensor) Front right 6 second pause Rear right 6 second pause Rear left 6 second pause. Each tire pressure sensor responds in turn so the module can establish the sensor positions at the start of the drive cycle. This process is repeated up to three times but less if the sensor positions are already known in the module. The process is known as 'Auto Location' and takes 3 to 4 minutes on vehicles fitted with 433 MHz systems and 7 to 8 minutes on vehicles fitted with 315 MHz systems to complete. During this period the tire sensors transmit at regular intervals, once every 5 seconds on vehicles fitted with 433 MHz systems and once every 15 seconds on vehicles fitted with 315 MHz systems. For the remainder of the drive cycle the tire sensors transmit once every 60 seconds or if a change in tire pressure is sensed until the vehicle stops and the system returns to parking mode. Once the wheel position is established, the initiators stop firing a signal and do not fire again until the vehicle has been parked for more than 15 minutes. The signal transmissions from each wheel sensor continue at 1 minute intervals whilst the vehicle is being driven. This transmission is to monitor the tire pressure. At 25% deflation the amber warning indicator in the instrument cluster is illuminated and an appropriate message displayed in the message centre. Hope this helps.  Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award | ||
|  Thu Dec 27 2007 12:03am |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | Nice work Bobby!   | ||
|  Thu Dec 27 2007 9:03am |
| daveysport Member Since: 17 Dec 2007 Location: Lincoln Posts: 22      | Fermier
|  Sun Dec 30 2007 3:42pm |
| Posting Rules
