![]() | Home > General > HSE Spare Wheel 20" or 19" |
| Imo Member Since: 05 Aug 2007 Location: Shropshire Posts: 12
Hello fellas,
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944
Full size spares are all 19s regardless of whether you run on 19 or 20" wheels... At least you still get full sized spares in the UK, here in the US they started mounting compacts on both HSE and even S/C last year. |
I don't see why not. I was able to (barely) jam an 18" rim and all terrain tyre with a total diameter / circumference much larger than either stock 19 or 20" up there - although that required removal of the heat shield and partial deflation of the spare... So, I am pretty sure a 20" rim with stock tyre, which has pretty much the same overall dimensions as the full size 19", would fit in that well without any issues. |
I agree also, a 20" would have plenty clearance underneath; pitty Land Rover don't think the same, sure they'll use the size issue as an excuse and of course fit a cheaper spare - got to make the profits where they can, talking of which I suppose I must be thankful that I got a spare at all and not a can of gunge. |
| Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435
With my MG ZT260 because it is converted from front wheel drive to rearwheel drive the diff had to go where the spare used to sit so I got 2 cans of gunk with the car. The stuff is about as useful as a chocolate fire guard, after a spate of punctures to the rear by the time you get stopped the inside of the tyrewall is destroyed and the gunk just runs out |
| G4LAND Member Since: 16 Jan 2007 Location: VIGO Posts: 154
What about the offset (275): may it can result, that the spare go to down; is that possible? Yuri
The offset is the same on all stock rims, 19 and 20 included... The 20" is slightly wider, so it will hang maybe a centimeter or two lower than the 19". No big deal. |
| ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823
My TDV8 has a 20"spare |
You guys all got lucky, better hope Land Rover doesn't take your full size spare away upon your next service visit: |
TDV8 20" standard |
| All times are GMT |
