| RRSPORT.CO.UK | ||
|  | Home > General > HSE Spare Wheel 20" or 19" |
| Imo Member Since: 05 Aug 2007 Location: Shropshire Posts: 12      |
 Hello fellas,
|  Sun Aug 05 2007 2:22pm |
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944      | Full size spares are all 19s regardless of whether you run on 19 or 20" wheels... At least you still get full sized spares in the UK, here in the US they started mounting compacts on both HSE and even S/C last year.   | ||
|  Sun Aug 05 2007 3:31pm |
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944      | I don't see why not. I was able to (barely) jam an 18" rim and all terrain tyre with a total diameter / circumference much larger than either stock 19 or 20" up there - although that required removal of the heat shield and partial deflation of the spare... So, I am pretty sure a 20" rim with stock tyre, which has pretty much the same overall dimensions as the full size 19", would fit in that well without any issues.  | ||
|  Sun Aug 05 2007 8:26pm |
| Imo Member Since: 05 Aug 2007 Location: Shropshire Posts: 12      | I agree also, a 20" would have plenty clearance underneath; pitty Land Rover don't think the same, sure they'll use the size issue as an excuse and of course fit a cheaper spare - got to make the profits where they can, talking of which I suppose I must be thankful that I got a spare at all and not a can of gunge. | ||
|  Sun Aug 05 2007 8:51pm |
| Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435      |
 With my MG ZT260 because it is converted from front wheel drive to rearwheel drive the diff had to go where the spare used to sit so I got 2 cans of gunk with the car. The stuff is about as useful as a chocolate fire guard, after a spate of punctures to the rear by the time you get stopped the inside of the tyrewall is destroyed and the gunk just runs out  Happened on the M74 southbound and had to get AA relayed home to Sunbury | ||
|  Sun Aug 05 2007 10:55pm |
| G4LAND Member Since: 16 Jan 2007 Location: VIGO Posts: 154    | What about the offset (275): may it can result, that the spare go to down; is that possible? Yuri
|  Mon Aug 06 2007 11:01am |
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944      | The offset is the same on all stock rims, 19 and 20 included... The 20" is slightly wider, so it will hang maybe a centimeter or two lower than the 19". No big deal.  | ||
|  Mon Aug 06 2007 4:35pm |
| ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823      | My TDV8 has a 20"spare  | ||
|  Mon Aug 06 2007 6:14pm |
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944      | You guys all got lucky, better hope Land Rover doesn't take your full size spare away upon your next service visit:   | ||
|  Mon Aug 06 2007 6:28pm |
| ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823      | TDV8 20" standard  | ||
|  Mon Aug 06 2007 6:30pm |
| Posting Rules
 that means that a 20" will fit others, surly
