![]() | Home > General > Private Number Plates |
| Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905
I think it looks quite good! Runner up - 2009 Best Avatar Award |
| Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285
Just noticed my rear number plate is just stuck on, no screws, what's the best way to remove it, just tried to ease it but it is well and truly stuck on... |
Dental floss and a hairdryer together will be the easiest way, then a spot of white spirits on a rag to remove the residue left from the sticky pads! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Dental floss and hair dryer it is then, thanks...still undecided about the rear large plate though |
The same method will remove the badges from the hatch if you want to debadge the car 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
What....debadge the car after I went to all the trouble of fitting black badges |
I've seen one and TBH it doesn't look right at the back, the badges break up the size of the lower section of the rear hatch 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| XUJG Member Since: 03 Aug 2006 Location: Left Posts: 437 |
15lb Fishing line will also cut through the adhesive without the need for a hair dryer.
| All times are GMT |
