Home > Off Topic > Wireless Network Help
Pelyma
Hopefully you clever chaps can help me. I have a Netgear router connected to my PC by a cable. I have a new laptop that is wireless enabled but though it can find the network and I give it the key will not connect Evil or Very Mad Any ideas? BTW I love BMWs Embarassed
Post #108206 Fri May 11 2007 1:19pm
chorlton
Check the encryption you are using? Is it WEP or WPK
Post #108210 Fri May 11 2007 1:23pm
Pelyma
WPA-PSK is what the paperwork I printed off says; does this make sense? Embarassed
Post #108219 Fri May 11 2007 2:01pm
mlines
Always worth tackling these things in small steps by removing all the hurdles and then adding them back in one by one.
Turn off all encryption/protection on the wireless router and then get the laptop to connect and check for correct operation - then turn back on the encryption and check again.
Martin 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #108226 Fri May 11 2007 2:18pm
PauloAmore
Scotland
Check that wireless that MAC addressing is switched off on the router.
(That allows the router to connect only to certain equipment bearing the serial numbers (Mac addresses)) 2022 P440e AB
Post #108227 Fri May 11 2007 2:23pm
Pelyma
If I change to open network it connects, so I switched back (checking passwords) and it doesn't Big Cry
Post #108228 Fri May 11 2007 3:00pm
PauloAmore
Scotland
Do you have data encyrption (a windows setting) set to TKIP not AES?
Also, apply all windows service packs (i think you need min SP1 for WPA-PSK).
If the above doesn't work, reset the router back to factory settings and start again. 2022 P440e AB
Post #108268 Fri May 11 2007 6:10pm
I go to a lot of problems like this, key in the wireless key and it works straight away - customer informs me that is what they were doing, however it didn't work for them Confused Wink
as Paulo says - reset the router and start again - hope you get it sorted
Post #108272 Fri May 11 2007 7:10pm
Pelyma
Cheers chaps I'll give it another go tomorrow, wine is calling now!
Post #108281 Fri May 11 2007 8:45pm
