Home > General > 6 Pot Brembo v 6 Pot Land Rover Callipers |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4845 |
This is a copy of the L/R instruction to chamfer the brake pads, albeit the NAS one it should still apply to all vehicles with the six pots, the problem is it didn't work and they eventually introduced a new design/style brake pad to cure it.
Fri Mar 17 2023 9:47pm |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 225 |
Thanks for this read Col, I noticed it says to grease the side of the pads but no mention of the back of the pad where the pistons sit, Should this not be greased i thought someone said to?
Fri Mar 17 2023 11:34pm |
This was the instruction for the earlier pads, It looks like on later pads they fitted a different type of anti-squeal backing and did away with need for grease on it. I can't really comment on other people's experiences only my own, but as I said the EBC pads I fitted were straight out of the box and were spot on, and they had no chamfer on the top edge as the L/R instruction shows either. If I recall correctly the chamfer mod did not work and the squeal came back after a few miles, which is why they introduced a different pad, however I do not know who the latest pads was manufactured by.
Fri Mar 17 2023 11:54pm |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
Given the cause of brake squeal is predominatly due to the build up of brake dust, and by the pictures your brake disc dimples and grooves have this within, I suspect your issue is down to the discs, not the pads/calipers.
Sat Mar 18 2023 8:39am |
Thanks for your opinion Dave, Im starting to wonder if the upgrade was even worth it now with the amount of times i have had the Callipers off and now pads.
Sat Mar 18 2023 10:29am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
I've drilled and grooved discs with my 6 pots, and EBC yellows
Sat Mar 18 2023 11:29am |
Thats Good to hear mate i did notice they’re slightly quieter after refitting. It looks like on general ebc/grooved feedback they will come good and i can enjoy the ride again soon 👍 I have sent a message to the lads at Maltings 4x4 so im guessing they will respond with the same feedback allowing them more time to bed in. |
Sat Mar 18 2023 12:28pm |
EBC drilled and grooved discs front and rear with ebc pads well bedded in and not a peep out of them.
Sat Mar 18 2023 12:37pm |
Update on the noise Gents, I decided to take all the front pads off at the weekend and i have chamfered the to edging to 45 degrees as per the Landrover bulletin, I also shaved around 1mm of the face of the pad, I noticed only 1 pad was a tight push back it but all greased up and back on. The noise only starts after about 2 miles of driving so it must be heat related, Just spoke to the Specialist who sold the 6 pot calipers and he said to bring it in for the mechanic to take a look, Not sure what he would be looking at as theres nothing saying its this? I will teat drive it again a weekend after going for a longer drive.
Mon Apr 17 2023 2:02pm |
No One can help? |
Mon May 08 2023 12:00am |
Have you determined whether it is just the o/s or n/s wheel or both sides ?
Mon May 08 2023 1:22am |
SuperC Member Since: 24 Feb 2016 Location: Midhurst, West Sussex Posts: 59 |
I went slotted with EBC yellows a little while ago. Initially, they were good an pretty quiet but, then they started squealing like Ned Beatty in Deliverance for a couple of 000 miles and just took an age to bed in properly. Over time, it got progressively better and now, totally quiet. In my experience it just seems to take time and use to bed them in.
Mon May 08 2023 10:43am |
Thanks for that experience Stuart and very helpful for anyone else and at the minute i couldnt agree more.
Sun May 14 2023 8:49pm |
I do have a set of these that I got from the States to try out, figured they were replacements for the Redstuff which have been discontinued for SUV's, can't really comment on their performance yet though as have never actualy got around to fitting them.
Sun May 14 2023 9:54pm |
