Home > Maintenance & Modifications > Dipstick reading |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
Also despite him having a private jet, butlers, small islands etc he still sells parts from his RRS for extra cash |
Thu Oct 15 2009 9:28am |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
The classic of all time is here:
Thu Oct 15 2009 10:22am |
where's the one all about his private jet, the customization etc...... |
Thu Oct 15 2009 10:30am |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
make yourself comfortable, some of these are long:
Thu Oct 15 2009 11:14am |
Thu Oct 15 2009 1:20pm |
Upheld
Thu Oct 15 2009 1:24pm |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
Runner up - 2009 Best Avatar Award
Thu Oct 15 2009 1:25pm |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 |
Ah! Glad you brought this up Tim.
Thu Oct 15 2009 2:06pm |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
OK now taken a couple of photos and checked (as far as getting a little finger in the hole!) and there doesn't appear to be a captive nut or anything threaded to tighten the bolt into. Anyone got an idea how this is supposed to tighten?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Sun Oct 18 2009 6:59pm |
CJ Member Since: 29 Apr 2007 Location: Sunny Sussex Posts: 18 |
Had the self same thing on my TDV8 noticed it when I checked the oil after its first 600 miles, word of warning if not sorted asap, the tube will lift out from the block and you will start to smell oil fumes around the front of the car BTW I did try to sort it myself but it requires the correct bush and nut assembly. My quick fix was a couple of cable ties
Mon Oct 19 2009 7:13pm |
Thanks for the warning. I've been doing a little more research and wondered if it's actually one of these that effectively work like a rivet
Mon Oct 19 2009 9:39pm |
