Home > General > Thinkware F770 2CH Dash Cam. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4845 |
Had them in most of the day, but have been playing about with them both on and off during the day so probably not a good test yet, have just completely reformatted one will put in in the car and see what happens over the next couple of day's. It should spend the next few hours recording the inside of the garage door as it's nearly midnight here. Will let you know what happens.
Sat Feb 17 2018 11:18am |
Another - so after a week the dashcam turns itself off after approx 30 secs from start up I've had the ctek on it and fully charged the battery - the FBH works off the plipper & timer which suggests it's not the battery BUT the auto stop start is highlighted on the dash panel which does suggest low battery I've put the 12v lead in the cam & reset as per the manual & plugged it back into the hardwired cable but no change
Thu Feb 22 2018 10:21pm |
Were you doing anything with the camera when it happened or was it just switched on as normal. Could try updating the Firmware if you haven't already as they have recently released an update, only a suggestion though.
Fri Feb 23 2018 10:27am |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 |
@Peachy
Fri Feb 23 2018 2:14pm |
Col - npinks - thanks both for your input & feedback
Mon Feb 26 2018 8:09am |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
Morning,,you guys mention a update for the 770,,where do I get this so I can do it on both my cams & wheres the best place to get the 128gb card from.?
Mon Feb 26 2018 8:57am |
Andy, you can download update from here. http://www.thinkware.com/Support/Download I got my 128GB cards from Amazon. https://www.amazon.co.uk/SanDisk-microSDXC...dpSrc=srch Cheers Col Last edited by Col on Mon Feb 26 2018 10:11am. Edited 1 time in total |
Mon Feb 26 2018 9:59am |
Thanks Col.
Mon Feb 26 2018 10:11am |
