Home > Maintenance & Modifications > Rear callipers. |
I now need 2 rear brake callipers as mine are siezed. I`ve emailed Dan at Duckworths but I`ve also looked online and found refurbed ones for around £100 a pair...would they be ok to use.....?
Tue Nov 14 2017 6:02pm |
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 |
These are the ones I had put on.
Tue Nov 14 2017 6:51pm |
So £125.60 with the £60 off for return item? They must refurb them then. Steve. |
Tue Nov 14 2017 6:57pm |
No home delivery Steve. |
Tue Nov 14 2017 6:59pm |
That`s my worry now, I`ve just had new discs and pads...need to sort soon. Steve. |
Tue Nov 14 2017 7:01pm |
Just don't drive it and make it worse Noisy black one |
Tue Nov 14 2017 7:04pm |
I won`t need it till Saturday but then I need it for work. Steve. |
Tue Nov 14 2017 7:05pm |
Über Noisy black one |
Tue Nov 14 2017 7:06pm |
I think best bet will be Euro Car Parts cos I could pick some up tomorrow and maybe get them fitted by the end of the week Steve. |
Tue Nov 14 2017 7:56pm |
How do you know they are seized? Unless the brakes are getting very hot it may be less of a problem than you think and hence not quite so urgent? Most of the braking effort is created by the front brakes after all. If you have a good motor factor nearby they should be able to offer you new calipers or remanufactured calipers at a decent price instantly or with next day delivery. All the calipers probably need is dismantling, cleaning and reassembling with new seals. Unfortunately most if not all garages can't be bothered with that 'old school' approach and just want to slap on a brand new pair. 2008 MY Java Black TDV8 HSE |
Tue Nov 14 2017 8:07pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
I purchased a brand new rear one off ebay for £40 !
Tue Nov 14 2017 8:08pm |
Hi Paddi. When he fitted the discs and pads a while back he freed them off. I asked him to investigate a squeak and that`s when he saw they were seized again. They were getting hot, you could smell them
Tue Nov 14 2017 8:10pm |
He did have a good look and didn`t see anything obvious which would cause it...ie crud etc. Steve. |
Tue Nov 14 2017 8:12pm |
I guess you need to know where to look. |
Tue Nov 14 2017 8:13pm |
