Home > Maintenance & Modifications > Rear callipers.
Cymruambyth
Wales
Rear callipers.
I now need 2 rear brake callipers as mine are siezed. I`ve emailed Dan at Duckworths but I`ve also looked online and found refurbed ones for around £100 a pair...would they be ok to use.....?
Example https://www.ebay.co.uk/itm/landrover-disco...SwL7VWnQPm Steve.
Post #540833 Tue Nov 14 2017 6:02pm
LJRH
These are the ones I had put on.
https://www.gsfcarparts.com/parts/braking/...ke-caliper Noisy black one
Post #540838 Tue Nov 14 2017 6:51pm
Cymruambyth
Wales
So £125.60 with the £60 off for return item? They must refurb them then. Steve.
Post #540842 Tue Nov 14 2017 6:57pm
Cymruambyth
Wales
No home delivery Confused Steve.
Post #540846 Tue Nov 14 2017 6:59pm
LJRH
I paid something in the region of £70 each and £50 to fit. They were properly seized and damaged the discs so they also had to be replaced along with pads. Noisy black one
Post #540847 Tue Nov 14 2017 7:00pm
Cymruambyth
Wales
That`s my worry now, I`ve just had new discs and pads...need to sort soon. Steve.
Post #540848 Tue Nov 14 2017 7:01pm
LJRH
Just don't drive it and make it worse Noisy black one
Post #540849 Tue Nov 14 2017 7:04pm
Cymruambyth
Wales
I won`t need it till Saturday but then I need it for work. Steve.
Post #540850 Tue Nov 14 2017 7:05pm
LJRH
Über Noisy black one
Post #540851 Tue Nov 14 2017 7:06pm
Cymruambyth
Wales
I think best bet will be Euro Car Parts cos I could pick some up tomorrow and maybe get them fitted by the end of the week Very Happy Steve.
Post #540861 Tue Nov 14 2017 7:56pm
Paddi
Re: Rear callipers.
How do you know they are seized?
Unless the brakes are getting very hot it may be less of a problem than you think and hence not quite so urgent? Most of the braking effort is created by the front brakes after all.
If you have a good motor factor nearby they should be able to offer you new calipers or remanufactured calipers at a decent price instantly or with next day delivery.
All the calipers probably need is dismantling, cleaning and reassembling with new seals. Unfortunately most if not all garages can't be bothered with that 'old school' approach and just want to slap on a brand new pair. 2008 MY Java Black TDV8 HSE
Post #540862 Tue Nov 14 2017 8:07pm
I purchased a brand new rear one off ebay for £40 !
No faffing with exchanges.
However I think I have identified the common problem.
Just where the rubber seal starts is a groove in the metal.
Rubbish accumulates in here and prevents everything moving.
Try cleaning this out with a sharp object.
small Screwdriver blade ?
and see if that helps. You could try one side.
Paddi: I tried fitting a new piston and seal and only half fixed the problem. Thus have identified the real issue above.
Post #540863 Tue Nov 14 2017 8:08pm
Cymruambyth
Wales
Hi Paddi. When he fitted the discs and pads a while back he freed them off. I asked him to investigate a squeak and that`s when he saw they were seized again. They were getting hot, you could smell them Embarassed
As you say, there`s a eurocarparts local so I`ve just ordered a pair Thumbs Up Steve.
Post #540865 Tue Nov 14 2017 8:10pm
Cymruambyth
Wales
He did have a good look and didn`t see anything obvious which would cause it...ie crud etc. Steve.
Post #540866 Tue Nov 14 2017 8:12pm
I guess you need to know where to look.
Post #540867 Tue Nov 14 2017 8:13pm
