![]() | Home > Maintenance & Modifications > Rear callipers. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 1788 ![]() ![]() ![]() |
Their the worst |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1005 ![]() ![]() ![]() |
Or wanted to work for himself instead of a dealer. Steve.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 370 ![]() ![]() ![]() |
You can just repair the caliper yourself. Most likely it's the sliding pins on the caliper. Fairly easy to replace, just got to ensure you fully clean all the muck out and add a bit of grease, but not to much that it suffers from suction. Even if the piston it is fairly easy to replace.
Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1530 ![]() ![]() ![]() |
I'm not going to get involved in the debate about ex LR fitters as I'm sure there's both good and bad.
