Home > General (L494) > RR Sport builder changes |
Edd, IIRC the cars you configure now will not start rolling cown the production line until mid August, possibly later so you may find that if your build date is before mid-August you will not be able to add these items............. ie you will have one of the last 2015MY cars. The hands free tailgate appears also to have been rolled out for Evoque too which also gets the option of LED headlights on some models. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Apr 03 2015 8:48am |
eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93 |
Hmmm mine is slated for a June build I wanted an ebony ebony interior but was told that ebony/lunar was as close as they got. Can't hurt to ask I guess. |
Fri Apr 03 2015 9:02am |
Good luck - might be worth going through Pete@land Rover rather than the dealer (wouldn't mind betting that 90% don't even know the configurator has changed so will be surprised when you ask!) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Apr 03 2015 9:39am |
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 |
Am I the only one who doesn't unnderstand the need to LED headlights? I though the current Xenons were good enough.... Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more...
Fri Apr 03 2015 9:41am |
Chris - My Defender is in having some TLC and the carriage lights with a tealamp in each wing are being replaced with LED headlights - I might be able to drive places at night without the Red Flag man infront afterward! I don't see the need on modern cars other than the designers can design even weirder shaped and more expensive lighting units. I decided to go for them on the Defender as the car has fragile wiring and is 19 years old. I have had lots of problems with blowing lamps in damp weather and was advised that replacing the candles with LED's puts less power drawn on wiring and battery/ alternator unlike BiZenons that require huge voltages to run. I have run LED side lights, brake lights and indicators on it for 7 years after replacing the LR Mushroom fittings for the brake lights several times a year, I haven't needed to change a lamp in 7 years and have rear lights that a lot of people think are rear fogs they are so bright yet they look like the OEM fittings! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Apr 03 2015 9:51am |
Chris have a look at the audi matrix led to see some advantage of LED http://www.audi.com/content/com/brand/en/v...light.html |
Fri Apr 03 2015 10:54am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
One potential benefit of LEDs is the high lifetime compared to standard bulbs. Also they require less energy although once you have an array of them that's probably no longer true.
Fri Apr 03 2015 11:12am |
Don't forget to factor in the cost of the extra research they will have to do to make sure the condensation is present at all times |
Fri Apr 03 2015 11:17am |
Maidenmania Member Since: 13 Feb 2014 Location: Yorkshire Posts: 138 |
It would appear the new model will also have automatic access mode...... At long last! 2008 Factory HST- Sold
Sat Apr 04 2015 7:53am |
Solihull1 Member Since: 01 Mar 2015 Location: Solihull Posts: 87 |
Does that mean that it will automatically lower to access height when turning engine off rather than pushing the button, or is there something bigger that I am missing? Thanks |
Sat Apr 04 2015 9:52am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1667 |
Not the brightest idea if so as access mode is best enabled with the car moving (slowly). |
Sat Apr 04 2015 10:13am |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 |
Just come home from the dealer , my order is being put on hold so that I will get one of the first of the new ones , they were aware of the changes but not aware the configurator had changed so much .
Sat Apr 04 2015 1:21pm |
HSE doesn't get Meridian now so 825w Meridan is £1000 and the Signature is £5000; AB still has 825 Meridan system so Signature system is £4k. |
Sat Apr 04 2015 1:49pm |
What is your delivery date now? |
Sat Apr 04 2015 2:06pm |
