Home > Technical > Disabling Door and Seatbelt Gongs |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
I find the gongs that sound when the drivers door is open with the key in the ignition and the gong that sounds when the seat belt is not on annoying and would like to disable them. I do drive with the seatbelt on but there are some offroad occasions and backing trailers that the seatbelt is off and the gong is annoying and distracting.
Mon Jan 31 2011 12:02am |
I did and the only thing that came up was the in and out 9 times trick but the indicator light stays on all the time - I want the light to continue to work as it should but not the dinger. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Mon Jan 31 2011 2:39am |
Oh.. oh...
Mon Jan 31 2011 4:15am |
I understood that the light on the dash would always stay on - so I did not bother going through the procedure. On reflecting though, I thought that the information could be wrong or I misunderstood - and all is good.
Mon Jan 31 2011 6:45am |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
I don't think that you can disable that one Range Rover Vogue ‘17 TDV6
Mon Jan 31 2011 8:29am |
