Home > General > TOW BAR & ELECTRICS |
freedom Member Since: 20 Dec 2006 Location: YORKSHIRE Posts: 4 |
IS IT EASY TO WIRE THE ELECTRICS FOR A DETACHABLE TOW BAR, & ARE RRS PRE WIRED AT THE BACK? |
Wed Dec 20 2006 10:47pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Hi - welcome !! -I did mine in around 90 mins - few pointers I could give you but really quite easy. Good instructions - kit £75 ish. |
Wed Dec 20 2006 10:51pm |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
Agreed - it simply plugs in! |
Wed Dec 20 2006 11:16pm |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 |
so it took MAW 1.5hours to wire a plug |
Wed Dec 20 2006 11:46pm |
took an hour to get the light cluster off
Thu Dec 21 2006 9:35am |
THANKS FOR REPLIES,MAIN DEALER QUOTED £200.00 JUST FOR ELECTRICS. |
Thu Dec 21 2006 9:22pm |
Fitted?
Tue Jan 02 2007 11:18am |
dsingeruk Member Since: 10 Jul 2006 Location: UK Posts: 20 |
I just went in to buy mine and the dealer told me they wont work until I pay them £70 to reprogram the computer. Is this ture - did you all have to have the dealer reprogram your computer before the electrics worked? |
Sat Feb 03 2007 2:52pm |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
There is an almost identical thread running over on Disco3 about towing electrics. Check this out for more info:
Sat Feb 03 2007 4:57pm |
They are plug and play - the only programming needed is that there is a setup change to disable RRS rear fog lights when towing to reduce glare in the rear view mirror agaisnt say (and heaven forbid) a caravan in tow. If towing only trailers or bike racks etc not problem and only a problem anyway if the glare of fogs in rear view mirror is excessive.
Mon Feb 05 2007 11:02am |
Ive just spoken to Land Rover direct and they say it must be reconfigured; a new configuration file needs to be downloaded to the ECU and if I dont do it, it may mess up something else on the car.
Tue Feb 06 2007 3:53pm |
When I added extra driving lights the ECU needed to be reprogrammed. My dealer charged £25.00+VAT 2005 Zambezi TDV6 - Gone but not forgotten
Tue Feb 06 2007 3:59pm |
dsingeruk....
Obviously, any advice you get from forum members here can't be binding against your car blowing up, but it seems to be the case that plenty have done their own thing when it comes to the tow bar kit without any issue. If you want to line the stealer's pockets with even more of your hard earned cash, then feel free
Tue Feb 06 2007 4:00pm |
