Home > Technical > L320 rrs heated seat |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4864 |
If the fuse is ok, I would be inclined to start by checking the element is not burnt out, not unheard of.
Mon Jan 22 2024 10:36pm |
Ray1979 Member Since: 10 Dec 2023 Location: Rochester Posts: 13 |
Fuse is all good one under bonnet and in car checked most fuses. Light for seat comes on
Mon Jan 22 2024 10:41pm |
No certain this is the correct one but I think it is pre-facelift, might also be l/h/d, but not sure that would make any difference. Probably have to view in "my gallery" to enlarge.
Mon Jan 22 2024 11:20pm |
Cool thank u gives me somewhere to start |
Mon Jan 22 2024 11:26pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8860 |
The heating elements are split in to two bits - one for the squab and one for the seat back - but they're in series so if one fails you lose the lot. Not unheard of for them to burn out (had that on my old RRS) but you usually get a very hot spot for a while before it fails. 2012 SDV6 - it's missing a couple of cylinders
Tue Jan 23 2024 12:48pm |
I just have nothing at all at drivers side only owned about 7 months so could have burnt out possibly before I owned it is there anyway to run power direct to see if they work themselves |
Tue Jan 23 2024 12:52pm |
Unplug the element and do a continuity test on it, surely that must be the easiest option. Just look under the rear of the seat base and you will see the wire coming through the metal pan from the base, just unplug it and test.
Tue Jan 23 2024 9:10pm |
Thank u ill give that a try tomorrow. Went and picked up another amplifier tonight for stereo as mine only turns on when it feels like letting me listen to music. So will fit that and try seat again. |
Tue Jan 23 2024 11:03pm |
