Home > Technical > Removing heater plugs hot/cold ? The 5 K resistor. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4801 |
https://www.disco3.co.uk/forum/topic153396...p;start=60
Thu Jan 18 2024 11:48pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 303 |
https://disco3.co.uk/forum/topic191038.html
Fri Jan 19 2024 5:43pm |
Granted the GP are on a lot for optimum whatever.
Fri Jan 19 2024 8:58pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 342 |
I am engaged on a full exploration of this system.
Sat Jan 20 2024 1:43pm |
ppl have done it before you.
Sat Jan 20 2024 3:08pm |
be careful not to confuse RRS and Disco sensors. Mine is 16k at 3 deg and 10k takes it to 59 c Always listen to old people or when they die you will live on in ignorance.
Sat Jan 20 2024 3:46pm |
If you have a 2.7 the sensors should be the same. Unless the EU4 engine with the sensor by the airbox has different readings |
Sat Jan 20 2024 4:02pm |
Until I have this cracked I am not going to comment further. Always listen to old people or when they die you will live on in ignorance.
Sat Jan 20 2024 4:06pm |
New Year’s resolution? |
Sat Jan 20 2024 4:17pm |
