Home > Technical > Suspension fault - error C1A13-64
ShouldHaveStuckWithAudi
United Kingdom 2009 Range Rover Sport TDV6 HSE Santorini Black
Hi all, i'm planning to use this thread to post my particular issue and how i fixed it in case it can help anyone else as i didn't find a huge amount on the issue when i started looking.
I have a (new to me) 2009 RRS L320. Everything seems to be wrong with it but the main issue has been a suspension fault that told me to stay below 30MPH and it wouldn't change down from off road height. Having reset codes and the like i could get the front to lower, but not the back, then they would both go up.
Anyways, the error message i was getting was C1A13 (C1A13-64 to be precise) 'Pressure does not decrease when venting gallery'. It seems this is about the system working fine to increase pressure, but then can't dump it to drop back to normal/lower heights. At this stage, I suspect some element of the exhaust is blocked so will try to get the compressor off (will post a separate question on that) and then report back here what the problem is....to be continued
Post #638002 Mon Dec 11 2023 5:20pm
That does sound like the exhaust valve in the compressor (or some part of the tubing from it) is blocked/failed. 2012 SDV6 - it's missing a couple of cylinders
Post #638003 Mon Dec 11 2023 5:32pm
Ok, final update on this one...eventually got the bracket off and the old compressor out. Put a cheap (£75 from Amazon) replacement one in while i try to rebuild the original. A £2 collet in the male hex quick connect stud wouldn't hold so i was getting the C1A20 - Pressure Increase Too Slow When Filling Reservoir.
Pulled that compressor out and put in a third one (this time £70 from Amazon but doesn't look as well built as the £75 one) which is holding fine and no more (suspension!) errors.
As this is the first time i've ever seen LR / RRS suspension work, not sure if it's working correctly - seems very stiff, creaky and uneven to inflate (and even deflate). Is there any quick trick to making it smoother (and therefore probably faster)?
Post #638156 Sun Dec 17 2023 6:14pm
83series3
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Try it with the car in neutral and the handbrake off … the increase / decrease in suspension height slightly changes the wheelbase length for some scientific reason that I cannot fathom on a Sunday evening Smile
Post #638159 Sun Dec 17 2023 7:04pm
Funny enough, I noticed that exact same thing.... Is a bit smoother when it has 'room to move'... But was still clunky.
If you're telling me that's normal then all the better. Else keen to know what to spray/squirt, and where, to make it a bit less clunky.
Post #638171 Mon Dec 18 2023 12:40am
The bushes on a 2009 are going to be a bit worn by now so some creaking isn't unexpected. As for uneven rise, I think that's a classic "they all do that, sir". Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #638175 Mon Dec 18 2023 11:00am
