Home > Technical > Suspension fault - error C1A13-64 |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8857 |
That does sound like the exhaust valve in the compressor (or some part of the tubing from it) is blocked/failed. 2012 SDV6 - it's missing a couple of cylinders
Mon Dec 11 2023 5:32pm |
ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 20 |
Ok, final update on this one...eventually got the bracket off and the old compressor out. Put a cheap (£75 from Amazon) replacement one in while i try to rebuild the original. A £2 collet in the male hex quick connect stud wouldn't hold so i was getting the C1A20 - Pressure Increase Too Slow When Filling Reservoir.
Sun Dec 17 2023 6:14pm |
83series3 Member Since: 19 Sep 2021 Location: South East Kent Posts: 32 |
Try it with the car in neutral and the handbrake off … the increase / decrease in suspension height slightly changes the wheelbase length for some scientific reason that I cannot fathom on a Sunday evening |
Sun Dec 17 2023 7:04pm |
Funny enough, I noticed that exact same thing.... Is a bit smoother when it has 'room to move'... But was still clunky.
Mon Dec 18 2023 12:40am |
The bushes on a 2009 are going to be a bit worn by now so some creaking isn't unexpected. As for uneven rise, I think that's a classic "they all do that, sir". 2012 SDV6 - it's missing a couple of cylinders
Mon Dec 18 2023 11:00am |
