Home > Maintenance & Modifications > How much should I be paying?
Shaun W
After this years MoT, which she scraped through my 2010 TdV8, needs the following doing:
To supply and fit a pair of rear track control arms
To suply and fit a pair of front lower suspension arms
To supply and fit near side steering rack joint.
I have had a quote from the garage that carried out the MoT and at just under £2k feels a bit expensive, especially the mark up on parts. I have no issue with 6 hours Labour, but I don’t know any different.
What should I reasonably expect to pay for this work doing? 2010 HSE TdV8 in Stornoway Grey.
Powerful Roof Rails and Spare Wheel protector
Post #636429 Fri Oct 06 2023 5:53pm
Disco_Mikey
That is a bit steep. I'd expect more around £13-1400 inc alignment
Post #636431 Fri Oct 06 2023 6:38pm
Shaun W
Thanks 2010 HSE TdV8 in Stornoway Grey.
Post #636432 Fri Oct 06 2023 6:39pm
Shaun W
Update:
I am getting it done, including the rear knuckles for £1400.
Bad news is it also needs a front suspension airbag (£600), a new coolant tank (which I knew about and have one to fit when I get time) and a complete set of wheel nuts, which the tyr en place told me last week when I got new tyres on it (£85) 2010 HSE TdV8 in Stornoway Grey.
Post #637010 Wed Nov 01 2023 3:06pm
riverblanche
blimey £600 for the front air strut sounds a lot as well, there stripping some of the front down to do the other stuff anyway Shocked
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #637046 Fri Nov 03 2023 6:55pm
Pistnbroke
I suggest you get your spanners out and do it yourself ....about £300 for parts /
If you are not able to do it then you should not be driving a RR or you have a big wallet,
I just bought two rear air bags for £ 230 ....fitting is free if you DIY,
Dont spend money on old cars you never get it back. Always listen to old people or when they die you will live on in ignorance.
Post #637050 Fri Nov 03 2023 10:07pm
Shaun W
Thanks watched a you tube video and it does seem simple enough to do, now for some follow up questions:
1. Which part do I buy? They seem to range from £345 + VAT for BWI to £150 for Dunlop?
2. What équipement do I need? What spec Jack and how do I safely support it whilst working on it? I’m assuming ankle stands of some description.
3. I see I need a long spanner.
Need to work out whether it will be cheaper to buy the parts and extra kit, then I have the kit for next time, or pay someone to do it that has the kit. 2010 HSE TdV8 in Stornoway Grey.
Post #637255 Mon Nov 13 2023 9:19pm
