Home > Technical > What Tyre Pressues? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4850 |
Personaly I think 33psi in the rear is a bit low, I usally run mine at 36psi although I am on 275/45 x 21" wheel/tyre size.
Mon Sep 11 2023 8:03am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
I run mine 36f / 39r normally but add to the rear if I'm going to load it and travel any distance. 255/55/19.
Mon Sep 11 2023 9:28am |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 333 |
I suppose it depend on the accuracy of the tyre pressure gauge ....... Always listen to old people or when they die you will live on in ignorance.
Mon Sep 11 2023 6:27pm |
Mon Sep 11 2023 6:28pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 407 |
Hard to find any accurate air pump in a garage here yet alone precise, so I use my own at home - which is also helpful as regards the temperature of the tyre. (By the time I got to a garage the tyres were usually hot!)
Mon Sep 11 2023 8:07pm |
Yeah, have digital one in the car, and generally check mine after the car has been parked overnight.
Mon Sep 11 2023 10:35pm |
