Home > General > Changing odometer from KM to miles
JonnyCJ
My car is a 4.2 SC which went out to Singapore with the original purchaser (a British diplomat) and he then brought it back into the country in 2016.
As such, the odometer shows KM, although the speedo has been changed to mph.
Whilst the service history and MoTs show everything recorded in km, I’d like to change the odometer to record the current distance travelled in miles.
It’s not a simple question of holding down the trip re-set for a couple of seconds, so if anyone has a solution I’d be all ears.
Post #633901 Fri Jun 23 2023 8:26pm
TheWojtek
I believe SDD can switch it to miles when ran in engineering mode (full access to CCF). I personally wanted to do the opposite (my dads D3 comes from the US of A), but sadly there is a fault in the BCM of this very car preventing the CCF from being edited so never really got to it. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #633902 Fri Jun 23 2023 8:36pm
JonnyCJ
Thanks Wotjek - will investigate with my local indy.
Post #633903 Fri Jun 23 2023 8:46pm
Not sure you have to edit anything in the CCF, don't know if you can do it via the indicator stalk menu on the pre-facelift, but simply change mine on a facelift with the steering wheel menu button.
Try this.
Post #633904 Fri Jun 23 2023 9:22pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
On my 2005 I can do it as per Col's post. Barrie.
2005 RRS 2.7TDV6 from 2017 -2024. Best car I ever had.
Current: 2018 Ford Ranger Wildtrak 3.2
Post #633905 Sat Jun 24 2023 4:57am
JonnyCJ
Thanks Col - I can change the trip from km to miles on the main display, but not the small display to the right of it, which gives the total distance travelled.
Post #633906 Sat Jun 24 2023 6:43am
Perhaps it is only the facelift you can change it all on.
Post #633907 Sat Jun 24 2023 9:08am
JonnyCJ
Incidentally - thanks for “The Poznan” !
Post #633908 Sat Jun 24 2023 9:18am
garrycol
Australia
No is the same for earlier models. Its all in the handbook. If in doubt, read the instructions. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #633909 Sat Jun 24 2023 10:27am
That's why I posted the settings option pages for the pre-facelift cars, as the OP may not have one.
Post #633910 Sat Jun 24 2023 11:00am
TheWojtek
Exactly. The units for the central information display are easily changed with the "i" button on the stalk. The units for the odometer (the small display below the speedo) are fixed - however there is a position in the CCF that sets default distance unit for the whole car.
Haha, I can see what you did here Smile You're welcome! Regards etc.,
Wojtek
Post #633911 Sat Jun 24 2023 11:16am
JonnyCJ
Thanks Wotjek - so it’s definitely a case of going into the CCF ?
Post #633912 Sat Jun 24 2023 11:29am
TheWojtek
I'd have to sort my dad's BCM to be 100% sure, but I was playing with the CCF in my car when switching to digital cluster and when I set "mph" as the global measurement unit (not the secondary small speedo), my odometer started to show the mileage in miles as well. Regards etc.,
Wojtek
Post #633917 Sat Jun 24 2023 4:35pm
