Home > General > Changing odometer from KM to miles |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
I believe SDD can switch it to miles when ran in engineering mode (full access to CCF). I personally wanted to do the opposite (my dads D3 comes from the US of A), but sadly there is a fault in the BCM of this very car preventing the CCF from being edited so never really got to it. Regards etc.,
Fri Jun 23 2023 8:36pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 251 |
Thanks Wotjek - will investigate with my local indy. |
Fri Jun 23 2023 8:46pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4871 |
Not sure you have to edit anything in the CCF, don't know if you can do it via the indicator stalk menu on the pre-facelift, but simply change mine on a facelift with the steering wheel menu button.
Fri Jun 23 2023 9:22pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 408 |
On my 2005 I can do it as per Col's post. Barrie.
Sat Jun 24 2023 4:57am |
Thanks Col - I can change the trip from km to miles on the main display, but not the small display to the right of it, which gives the total distance travelled. |
Sat Jun 24 2023 6:43am |
Perhaps it is only the facelift you can change it all on.
Sat Jun 24 2023 9:08am |
Incidentally - thanks for “The Poznan” ! |
Sat Jun 24 2023 9:18am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
No is the same for earlier models. Its all in the handbook. If in doubt, read the instructions. 07MY RRS TDV6 Arctic Frost Aspen Interior |
Sat Jun 24 2023 10:27am |
That's why I posted the settings option pages for the pre-facelift cars, as the OP may not have one.
Sat Jun 24 2023 11:00am |
Exactly. The units for the central information display are easily changed with the "i" button on the stalk. The units for the odometer (the small display below the speedo) are fixed - however there is a position in the CCF that sets default distance unit for the whole car.
Haha, I can see what you did here You're welcome! Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Sat Jun 24 2023 11:16am |
Thanks Wotjek - so it’s definitely a case of going into the CCF ? |
Sat Jun 24 2023 11:29am |
I'd have to sort my dad's BCM to be 100% sure, but I was playing with the CCF in my car when switching to digital cluster and when I set "mph" as the global measurement unit (not the secondary small speedo), my odometer started to show the mileage in miles as well. Regards etc.,
Sat Jun 24 2023 4:35pm |
