Home > General > Noisy rear diff 4.2 SC
JonnyCJ
Just been under the car at the local garage’s pit. Slight weep and some movement on the right hand output going to the driveshaft.
Are rebuild kits available or should I get a recon diff ? Any advice or guidance welcome !
I’m in the North West.
Post #633614 Thu Jun 08 2023 11:43am
JonnyCJ
As an update, as I know you’re all on tenterhooks - JGS4x4 do a rebuild kit for £140 and Birch 4x4 1 mile from work can do the fitting, so all good !
Post #633646 Fri Jun 09 2023 4:18pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Thanks for updating
Post #633647 Fri Jun 09 2023 8:46pm
JonnyCJ
Could anyone advise what diff oil I need and how much, for a locking rear diff 2005 4.2 SC
Many thanks !
Post #633678 Mon Jun 12 2023 10:34am
Castrol BOT 720. Service refill 1.55 Liters.
Post #633679 Mon Jun 12 2023 10:52am
JonnyCJ
Thanks Col - much appreciated !
Do you know if it has a breather or is that the non locking diffs ?
Post #633681 Mon Jun 12 2023 11:31am
Both diffs have a breather, I believe. The top end of the breather sits up near the fuel filler. 2012 SDV6 - it's missing a couple of cylinders
Post #633682 Mon Jun 12 2023 12:24pm
JonnyCJ
Thanks - struggling to get BOT 720. Is the Rock Oil equivalent ok to use ?
Post #633683 Mon Jun 12 2023 12:28pm
Google Castrol SAF Carbon Mod plus as that's shown as well in later handbooks. I believe Ravenol MDL is also a equivalent.
Post #633684 Mon Jun 12 2023 12:32pm
JonnyCJ
Couldn't find the Carbon plus at an ok price either and JGS4x4 have the Rock Oil equivalent as an option instead of the BOT720, however, I couldn't get hold of anyone there, so called Blackhawk Solutions and spoke to a very helpful chap called Jerry.
First time I'd come across them and was very impressed with the knowledge and service, so popped in an order for a couple of litres. Price was extremely good too !
https://www.blackhawksolutions.co.uk/ro560...2785-p.asp
Post #633685 Mon Jun 12 2023 1:34pm
JonnyCJ
Bearing kit arrived yesterday - all are Timken, so top quality as far as I understand. Diff oil also arrived swiftly from Blackhawk Solutions, so looking forward to the rebuild next Monday.
Hopefully I'll get Birch to do a pictorial.
Post #633740 Thu Jun 15 2023 9:59am
JonnyCJ
Update ! Car was with Birch 4x4 in Liverpool for a couple of days. They removed the diff, cracked it open and found pretty much every single bearing in need of replacement. The bearing and seal replacement kit from JGS4x4 did the job and although it took a little while to get the diff out (partial exhaust removal, rear suspension partial removal, prop shaft removal) it was definitely worth doing.
The rear end sounds much much quieter now and luckily the internal gears were all perfect, with no chipping of teeth or wear.
If you have a noisy rear diff it’s worth a full rebuild for peace of mind.
£1,100 all in incl parts, labour and new diff oil, but I can now sleep at night.
Getting to the end of the jobs that need doing, but still sufficient to keep me occupied !
Post #633861 Wed Jun 21 2023 8:13pm
Stevepd
That's great and thanks for the update. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #633870 Thu Jun 22 2023 7:06am
