Home > General > Noisy rear diff 4.2 SC |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 240 |
As an update, as I know you’re all on tenterhooks - JGS4x4 do a rebuild kit for £140 and Birch 4x4 1 mile from work can do the fitting, so all good ! |
Fri Jun 09 2023 4:18pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 302 |
Thanks for updating |
Fri Jun 09 2023 8:46pm |
Could anyone advise what diff oil I need and how much, for a locking rear diff 2005 4.2 SC
Mon Jun 12 2023 10:34am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4856 |
Castrol BOT 720. Service refill 1.55 Liters.
Mon Jun 12 2023 10:52am |
Thanks Col - much appreciated !
Mon Jun 12 2023 11:31am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
Both diffs have a breather, I believe. The top end of the breather sits up near the fuel filler. 2012 SDV6 - it's missing a couple of cylinders
Mon Jun 12 2023 12:24pm |
Thanks - struggling to get BOT 720. Is the Rock Oil equivalent ok to use ? |
Mon Jun 12 2023 12:28pm |
Google Castrol SAF Carbon Mod plus as that's shown as well in later handbooks. I believe Ravenol MDL is also a equivalent.
Mon Jun 12 2023 12:32pm |
Couldn't find the Carbon plus at an ok price either and JGS4x4 have the Rock Oil equivalent as an option instead of the BOT720, however, I couldn't get hold of anyone there, so called Blackhawk Solutions and spoke to a very helpful chap called Jerry.
Mon Jun 12 2023 1:34pm |
Bearing kit arrived yesterday - all are Timken, so top quality as far as I understand. Diff oil also arrived swiftly from Blackhawk Solutions, so looking forward to the rebuild next Monday.
Thu Jun 15 2023 9:59am |
Update ! Car was with Birch 4x4 in Liverpool for a couple of days. They removed the diff, cracked it open and found pretty much every single bearing in need of replacement. The bearing and seal replacement kit from JGS4x4 did the job and although it took a little while to get the diff out (partial exhaust removal, rear suspension partial removal, prop shaft removal) it was definitely worth doing.
Wed Jun 21 2023 8:13pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1244 |
That's great and thanks for the update. 2006 2.7 TDV6 HSE in Cairns Blue. |
Thu Jun 22 2023 7:06am |
