Home > General > Invisible Silver RRS. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8856 |
You can set it up to have Canadian or Scandinavian lighting. One lights the dipped beams with ignition on, the other lights dipped beams and tail lights. Can't remember which. I think you can set it up in one of the menus on the car, or it might need a plug in diagnostic such as the IID Tool or the garage's system to change the CCF.
Fri May 19 2023 2:19pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4801 |
I thought Canadian turned the lights on, when in gear. (not Park) and park brake off too I guess
Fri May 19 2023 3:28pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1244 |
I mostly just turn the lights on after starting and switch off before turning the engine off. 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri May 19 2023 4:17pm |
I generally run with the headlights switched on too. The DRLs on the 2012 aren't that useful really; the headlights are noticeable. 2012 SDV6 - it's missing a couple of cylinders
Fri May 19 2023 4:24pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4858 |
I you do a search there are numerous posts on the subject, I posted this 7/8 years ago. Don't know if the same applies to a pre facelift L320 would imagine it does.
Fri May 19 2023 9:58pm |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
I replaced the fog lights with DRLs from Powerful, bought a simple controller on fleabay that dims them once the sidelights are switched on.
Fri May 19 2023 10:08pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
I bought the genuine Landrover DRL's many years ago but never fitted them as the isntructions stated off with the facelifted version and then changed to the non facelifted version for the inside fitting - all to hard. So I then bought the Osram fog/drl lamps which go in place of the original fog lamps - very easy fit and doesnt look aftermarket. |
Sat May 20 2023 1:19am |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 407 |
Barrie. 2005 RRS 2.7TDV6 from 2017 -2024. Best car I ever had. Current: 2018 Ford Ranger Wildtrak 3.2 |
Sat May 20 2023 7:07am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 426 |
I have the Scandinavia DRL function setup on my 2011. They come on on startup and stay on. The headlights, fairy lights, taillights and license plate lights all come on. It’s effectively turning on the headlights, but auto high beams, cornering lights and AFS don’t function. I leave the switch in auto and never think about my headlights.
Sat May 20 2023 7:49am |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 313 |
The active turning lights (or whatever they are called?) didn’t work when I got mine so I rewired them through a DRL relay which dims them with headlights on and replaced the bulbs with LED. Steve
Sat May 20 2023 9:38am |
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 |
Thanks for all the help & suggestions guys, a number of choices to consider.
Wed May 24 2023 9:57am |
Just get the factory DRL programming done, it takes about 10-15 minutes on diagnostics. If it’s available you can even get the timed FBH to come on. Works best if you have a pretty regular schedule. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed May 24 2023 2:08pm |
