Home > General (L494) > Keyless Locking stopped working on driver’s door |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 391 |
Mine stopped working a while ago but I think it was every door not just the drivers door. I pulled the fuse out relating to passive entry and left it out for a few minutes then put it back in. Been working ok ever since. I think it’s related to the KVM module, maybe needed a de power to reset it. The fuse is in the fuse box in the boot area. |
Sat Mar 12 2022 8:22pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
You can remove the outer cover, unfortunately it would appear you have to remove the complete handle first as the cover is retained by to small screws at one end.
Sat Mar 12 2022 10:01pm |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 152 |
Thanks both of you - very helpful.
Sat Mar 12 2022 10:29pm |
tangodown Member Since: 10 Apr 2023 Location: Cheshire Posts: 10 |
I have this exact problem, did you ever find a fix?
Mon Apr 10 2023 6:17pm |
You could try disconnecting the battery and leave for 20 mins then reconnect . It may re boot something. It’s what I would do before taking to a garage. These are complex cars and just need a re boot every now and again just like my PC……… |
Mon Apr 10 2023 7:03pm |
Never found a cure. It works about 50% of the time and I can lock it with any other handle so haven’t bothered getting too serious about it.
Mon Apr 10 2023 7:06pm |
I've got mine booked in with the local main dealer on 10th May for an outstanding recall on the keyless locking system, so I'll see what happens after that's done.
Tue Apr 25 2023 8:50pm |
Outstanding recall? How did you find out about that? I wonder if my car needs doing? |
Tue Apr 25 2023 10:05pm |
https://www.gov.uk/check-vehicle-recall 2014 L494 HSE |
Tue Apr 25 2023 10:19pm |
Just done the recall check and it says there are no recalls for my car…..Let us know how you get on and what they do please. |
Tue Apr 25 2023 10:38pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1747 |
Have you looked on Topix to see if there any outstanding campaigns? 2023 P440e SE Dynamic on order -cancelled
Wed Apr 26 2023 9:41am |
So recall work has finally been done and the problem is still there, if anything it's worse now. Getting out the car as soon as the driver's door is closed it goes into a mad spasm of trying to lock and unlock until I get out of range of the door. Nightmare!!! 2014 L494 HSE |
Wed Jun 14 2023 11:14am |
