Home > General (L494) > Keyless Locking stopped working on driver’s door
Punkawallah
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Adriatic Blue
Hi all,
So the keyless locking on the driver’s door doesn’t operate the locks when I touch it on the usual spot any more.
All the other doors work and the lock itself works fine and unlocks keylessly so it seems the sensor on the outside of the handle is to blame.
Unlike the L320, the L494 doesn’t seem to have handle covers that can be taken off - I was hoping to do this and perhaps clean underneath and it would work again.
Does anyone have any clever tricks to get this working again?!
Thanks a lot 2013 L494 V8 s/c Autobiography Dynamic
Post #622739 Sat Mar 12 2022 8:07pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Mine stopped working a while ago but I think it was every door not just the drivers door. I pulled the fuse out relating to passive entry and left it out for a few minutes then put it back in. Been working ok ever since. I think it’s related to the KVM module, maybe needed a de power to reset it. The fuse is in the fuse box in the boot area.
Post #622740 Sat Mar 12 2022 8:22pm
You can remove the outer cover, unfortunately it would appear you have to remove the complete handle first as the cover is retained by to small screws at one end.
Post #622743 Sat Mar 12 2022 10:01pm
Punkawallah
Thanks both of you - very helpful.
I’m not sure why but I’ve decided - as a first move - that I’m going to try using a hairdryer to warm up the handle tomorrow and possibly dislodge/dry-out any moisture lurking between the cover and the handle/locking sensor.
Next move will be as Col suggests! 2013 L494 V8 s/c Autobiography Dynamic
Post #622744 Sat Mar 12 2022 10:29pm
tangodown
United Kingdom 2013 Range Rover Sport SDV6 HSE Orkney Grey
I have this exact problem, did you ever find a fix?
I've tried pulling the KVM fuses but no joy, it started intermittently last summer and now it will only unlock and not lock using the driver's door handle sensors. All other doors are fine as is the remote.
Another issue seems to have reared its ugly head in that as I approach the drivers side the vehicle unlocks automatically when I'm still 6 feet away? This is coinciding with the battery draining overnight from full to completely dead. I have to leave it on a smart charger overnight, even after replacing both main and auxiliary batteries.
Mine is an early 2014 HSE and I've had it for 3 1/2 years with very little trouble until this issue.
Post #632242 Mon Apr 10 2023 6:17pm
Johnrrs
You could try disconnecting the battery and leave for 20 mins then reconnect . It may re boot something. It’s what I would do before taking to a garage. These are complex cars and just need a re boot every now and again just like my PC………
Post #632244 Mon Apr 10 2023 7:03pm
Punkawallah
Never found a cure. It works about 50% of the time and I can lock it with any other handle so haven’t bothered getting too serious about it.
Sounds to me like one of your door handles permanently “thinks” your hand is trying to open it and therefore as you approach the car, the car unlocks itself.
I guess both issues are prob related…. 2013 L494 V8 s/c Autobiography Dynamic
Post #632245 Mon Apr 10 2023 7:06pm
tangodown
I've got mine booked in with the local main dealer on 10th May for an outstanding recall on the keyless locking system, so I'll see what happens after that's done.
Don know if it will sort all my problems but I know they are replacing the KVM and doing a reprogram on it all. 2014 L494 HSE
Post #632679 Tue Apr 25 2023 8:50pm
Johnrrs
Outstanding recall? How did you find out about that? I wonder if my car needs doing?
Post #632682 Tue Apr 25 2023 10:05pm
tangodown
https://www.gov.uk/check-vehicle-recall 2014 L494 HSE
Post #632684 Tue Apr 25 2023 10:19pm
Johnrrs
Just done the recall check and it says there are no recalls for my car…..Let us know how you get on and what they do please.
Post #632687 Tue Apr 25 2023 10:38pm
jimbg
Have you looked on Topix to see if there any outstanding campaigns? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #632701 Wed Apr 26 2023 9:41am
tangodown
So recall work has finally been done and the problem is still there, if anything it's worse now. Getting out the car as soon as the driver's door is closed it goes into a mad spasm of trying to lock and unlock until I get out of range of the door. Nightmare!!! 2014 L494 HSE
Post #633721 Wed Jun 14 2023 11:14am
