Home > Maintenance & Modifications > TDV8 Alternator replacement |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
Update to the saga,, as to the question of loosening the ACE pump,,, bottom bolt would come out but don't think the top one would so no advantage there. The bracket that would help if loosened is impossible to get at so took off the bottom intercooler hose and pulled the pipe down and tied it off,,, which gave me an extra 15mm of clearance under the alternator,,,, doesn't seem much but makes a lot of difference. Takes an age to work the bolts down but managed in the end,, jiggled the alternator a bit and it came out. Refitting is quite tricky,,, especially when trying to get the two bottom bolts back in,found it was easier to get a couple of threads on the left hand one then get the other in place.,,,,, very awkward and time consuming but managed in the end. Decided to clean all the earth points while was busy,,, then called it a day to give my knuckles and fingers a rest 2010 RRS, TDV8
Mon Feb 20 2023 10:19pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1246 |
Good luck, I wouldn't even entertain the idea anymore. Paper, scissor, indie = indie wins. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Feb 21 2023 8:54am |
I quite enjoy tinkering about,, there was no great rush to finish and I have a garage to work in,, and a really good selection of tools,,, endless cups of coffee and music so quite comfy. Put back the top end of the engine bay today, topped off the coolant and reconnected the battery, started straight away. Voltage was only 13.8 and battery light still on but left it for a few minutes and checked again and was showing 14.7, no battery light and varying between 55 and 60 amps output. Spent a little time bleeding out the coolant system,,all seems fine. Next job is the rear tie rods,,,, but holiday in Dubai first. 2010 RRS, TDV8
Tue Feb 21 2023 8:27pm |
