Home > Maintenance & Modifications > Disabling gesture tailgate on a 2020 L494? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8863 |
Probably needs to be done in the CCF, unless it's got its own fuse. 2012 SDV6 - it's missing a couple of cylinders
Mon Jan 09 2023 10:52am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
It's got it's own connector to the sensor for sure, so disabling should be a single look under the bumper away... Regards etc.,
Mon Jan 09 2023 5:19pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4871 |
By simply pulling a fuse or unplugging it, would it not possibly throw up a annoying message when going through the system check, only a though as wouldn't really know, try it and see would be the obvious answer I guess.
Mon Jan 09 2023 10:51pm |
If it's doing it randomly it might be a sign of a deeper issue that simply disconnecting the sensor or fuse won't solve. Or if doing so does solve it, then it at least helps to narrow down the problem. 2012 SDV6 - it's missing a couple of cylinders
Mon Jan 09 2023 11:52pm |
Is there a separate fuse for the sensor, or does the fuse cover the whole powered tailgate stuff? Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Tue Jan 10 2023 10:16am |
I think it may be Fuse 49, 10 amp fuse in the rear load space fusebox, but wouldn't know if it controls the complete powered tailgate function or just the gesture part, proably the whole thing.
Tue Jan 10 2023 10:49am |
10A seems overkill for a simple sensor. BTW this sensor uses about as much energy as the rain sensor, so I believe there may even be no fuse for it at all.
Tue Jan 10 2023 12:37pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 529 |
I think I have succeeded! You can turn off the keyless opening on a post 2018 model with the later platform using the same method..
Sat Jan 14 2023 7:20pm |
Thank God the JLR engineers didn't include spitting over left shoulder while juggling 4 tennis balls into this procedure. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Sat Jan 14 2023 10:24pm |
