Home > General > Leaking anti-roll bar |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 206 |
Hi have you looked at Advance Factors a site supporter for this site ? Always found them good with quality and service for items I have purchased from them. |
Fri Oct 14 2022 12:58pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
I'm surprised the OEM one is that price. I'd have expected it to be c.£600-700 + VAT. 2012 SDV6 - it's missing a couple of cylinders
Fri Oct 14 2022 1:54pm |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
Front or rear ARB? 2010 TDV8 - current - my first RRS, loving it so far......
Fri Oct 14 2022 3:15pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Be careful when buying something labelled as OEM. Sometimes parts are labelled OEM by the retailer and that's because the manufacturer is an OEM to Land Rover, for a completely unrelated part eg. a tyre valve cap. It doesn't necessarily mean they are the OEM for that exact part.
Fri Oct 14 2022 4:01pm |
OEM (by BWI) unit at Advanced Factors: https://www.advancedfactors.co.uk/lr024073...4124-p.asp
Fri Oct 14 2022 4:56pm |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 239 |
Thank you everyone for the info.
Sat Oct 15 2022 9:52am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Have you checked with Rob in R&E and also Steve at T&S normal to see what they come up with. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sat Oct 15 2022 10:33am |
Update: I’ve had a new rear bar fitted. The bar was OEM and was manufactured by BWI. I’ve been lead to believe that BWI actually make the bars for Land Rover. It cost £499+ VAT from Island-4x4 if anyone is interested. |
Fri Nov 18 2022 5:08pm |
Forgot to add that it now corners like it used to without it wallowing around. |
Sat Nov 19 2022 12:08pm |
Baker3570 Member Since: 28 May 2021 Location: cumbria Posts: 51 |
hi sorry for jumping in on your post, did you fit the bar yourself or did a garage do it? if so how much was the total job as i think i could need one soon! |
Tue Nov 22 2022 1:15pm |
Bought the bar myself for £600 inc vat and was fitted by a local LR specialist for about £400 in labour costs alone. I have been told that it’s not an easy job cos the chassis has to be unbolted from the body. The bar won’t come out without doing this. |
Tue Nov 22 2022 1:41pm |
